Panniers or rack top bag?
  • This topic has 23 replies, 22 voices, and was last updated 12 years ago by smuggers.
  • #22703
    craig749
    After commuting for the last few years using a rucksack the time has finally come to try some form of pannier. As I only really carry food and a small amount of clothing I can’t decide if to go for full panniers or a rack top bag?
    Have any of you tried either or both? If so which would you recommend?
    Thanks
    Craig
Viewing 8 replies - 16 through 23 (of 23 total)
  • #820325
    adamtaylor
    I can’t recommend a rack and
    I can’t recommend a rack and pannier enough. It’s so much nicer than using a rucksack. I ride just with one pannier, it’s enough space and I don’t suffer from any balance or space problems.
    #820323
    I bought an Altura rack-top
    I bought an Altura rack-top bag. Used it twice. It’s nice enough but since I couldn’t fit as much in it as I had expected I went back to using a rucksack.
    One of the welds on the rack broke sometime after (it had not carried more than ~1.5kg while I used it but was s/h) so I took it off.
    If anyone wants the bag drop me a note, it’s like new. IIRC it looks like the Transit:
    http://www.wiggle.co.uk/altura-arran-transit-rack-bag/
    #820321
    gazza_d
    A lot depends on what you are
    A lot depends on what you are planning to carry, but I’d say panniers all the way.
    Plenty of space for the unplanned trip on the way home or to stuff a jersey or raincoat in without having to faff about rolling it ultratight to fit into a small space.
    Make sure you buy seperable ones where you can use just one, and not the el-cheapo all-in-one wardrobe sized ones from the likes of Argos.
    Unless you buy Ortleib or manage to find the Aldi rip offs, buy some rubble sacks or rucksack liners to use as inner bags to keep everything dry for that commute when it’s chucking it down..
    #820319
    andyp
    ‘I would not be that bothered
    ‘I would not be that bothered with panniers, for trips in town I have always found them a pain, they seem to catch on everything ‘
    This has *never* happened to me. Panniers fo’ sure.
    #820317
    dave atkinson
    I use a pannier most of the
    I use a pannier most of the time. if you’re going to work and back and planning to take it inside then it’s the most versatile solution, i find. you can stick a bunch of shopping in there too. i have a carradice saddle bag too which i’d use in preference if i was doing a long ride and i knew what i was carrying. but panniers allow you to shift stuff you didn’t allow for a lot easier.
    #820315
    MKultra
    If you have the money I would
    If you have the money I would go for a Carradice saddle bag.
    Other than that I would not be that bothered with panniers, for trips in town I have always found them a pain, they seem to catch on everything and you are constantly having to remove them if you need to leave the bike unattended.
    I prefer a day sack as it lets me mix in tow paths on the route, you can cyclo-cross carry the bike easily and you don’t have panniers to catch on anti motorbike kissing gates.
    #820313
    Shades
    Panniers all the way and
    Panniers all the way and stacks of choice out there (in comparison to rack bags which are pretty limited in their capacity). They don’t slow you down either and you avoid the rucksack sweaty back. In support of rack/saddle bags, I did spy a Carradice bag the other day. Quite smart and a bit ‘retro’, but probably not cheap.
    #820311
    putmebackonmybike
    Bit of an odd questions…
    Bit of an odd questions… but panniers are just easier? Get the ones you can just clip out and walk off with to yer desk.
