Tubs users…
  • This topic has 19 replies, 14 voices, and was last updated 12 years ago by step-hent.
  • #22559
    Super Domestique
    …glue or tape?
Viewing 4 replies - 16 through 19 (of 19 total)
  • #817655
    therevokid
    glue …
    glue … 🙂
    #817653
    JohnnyRemo
    Glue of course – it’s what
    Glue of course – it’s what the pros do…
    #817651
    Scrufftie
    I’m lazy so I use tape.
    I’m lazy so I use tape. Given the effort required to remove a tub once it’s been taped on, I’d be very surprised if it rotated on the rim or were affected by wet conditions.
    On the plus side, tape doesn’t need to go off before mounting and is probably cheaper.
    On minus side, getting the tub accurately centred with most tapes can be a little tricky, the paper-backed ones especially.
    If you decide to go down the tape route, I recommend Tufo tape. The backing is plastic, which makes getting centred a doddle and it doesn’t break when removing it. It’s quite a bit more expensive than other tapes, though, and each pack is for one tyre only. Still, you shouldn’t be removing the tubs too often, especially if you stick a bit of sealant in each tyre.
    #817649
    edster99
    glue – ive tried tape and its
    glue – ive tried tape and its ok in the dry, but not in the wet where it can rotate on the rim a bit (IME). Glue works great in both wet and dry. Its slightly harder to remove a glued tub but if you have some tyre levers to start the levering off process its not difficult. I have swapped a tub from rolling to rolling again in 3 minutes (with glue).
