- This topic has 27 replies, 17 voices, and was last updated 12 years, 5 months ago by
arfa.
June 26, 2014 at 9:28 am #21770
MarcMyWords
Hi ladies and gents,
Any roadies out there using SPD rather than SPD-SL pedals? I’m a bit sick of struggling to engage and thought I’d give the SPD’s a try so bought a cheap pair off of eBay. Any recommendations on shoes? I don’t want to have to buy some chunky paid of MTB shoes…
Thanks
notfastenough
MarcMyWords
MarcMyWords wrote:notfastenough wrote:However, you do state that you’ve already bought the SPD pedals. I think SPD adapter kits are available for the 3-hole bolt pattern on most shoes.
Thanks for your post – I do have the pedals but they were only about £15 so if something else is better, I’m happy to sell them on / give them away and start again for the right pedal and I’m hearing lots and lots of positives about Speedplay.
Ah, ok. I chose them because they give you a large pedalling platform (check out the size of the cleat compared to others, they’re double-sided and the float is not spring-loaded. It’s neutral, which means that the pedal doesn’t keep trying to pull you back to it’s central position. I’ve had knee issues in the past.
Check this out – I don’t think this has spd on the list, but the comparions are interesting all the same:
http://www.speedplay.com/index.cfm?fuseaction=roadcompare.compareroadI use Specialized Body Geometry shoes, but that’s partly because the sole is laterally tilted, with a built-in 1.5mm varus wedge. I actually require about 4.5mm varus wedging, which is difficult to achieve while leaving enough room in the shoe for your foot, so that built-in amount has value to me.*
There are shoes with 4-hole bolt patterns specifically for Speedplay, which are worth looking at because they allow you to do away with the adapter kits that allow you to use speedplay on shoes with 3-hole patterns. This is good because it reduces the distance between the sole of your foot and the pedal axle. These shoes are usually at the pricier end of the scale though. Off the top of my head, I think Lake, Northwave and Sidi each have a speedplay-specific shoe.
*If this is jargon is sounding like a mystery, check out the Specialized Body Geometry websites to understand more. You may be one of those people who can use any fitting shoe without a problem, but you could also be the kind with more specific requirements. It would be a shame to spend your money on something that turned out to be unsuitable.
Let me know if you have any other questions.
parksey
If it’s of any use, I started
If it’s of any use, I started the following thread back in January which ended up with a fair amount of input, so might be worth a quick read:http://road.cc/content/forum/109722-beginners-advice-pedals-shoes
Notwithstanding the generally positive recommendations for “normal” SPDs on road bikes, I was eventually swayed by the advice of my LBS and went for SPD-SLs. I use them daily for commuting on the bike and don’t have any problems clipping in/out (after my requisite three stationary falls whilst learning…), I’m using Shimano R550 pedals with the tension set in the middle.
No problems for me actually walking in them either, not that I walk miles in them but I can get up and down stairs without difficulty. The concern is that the yellow Shimano cleats I use have basically worn out already after only 4 or so months, although all the walking on the London to Brighton ride weekend before last really didn’t help…
60kg lean keen climbing machine
Shimano A600 pedals and RT82
Shimano A600 pedals and RT82 shoes, I use RT82 shoes which are brill but currently run with cheap 520 pedals, will soon be buying some A600 as they have good reviews!! I use my bike for fun and for transport so prefer to be able to walk like a normal person off the bike and when in town much better for the stop start traffic.MarcMyWords
However,notfastenough wrote:However, you do state that you’ve already bought the SPD pedals. I think SPD adapter kits are available for the 3-hole bolt pattern on most shoes.
MarcMyWords
Interesting about the Crank
Interesting about the Crank Brothers, not seen those before but having a look now at some promising reviews. And they look like they fix in with a 2 bolt system?gdmor10
I had SPDs on my road bike
I had SPDs on my road bike for ages then changed them to SPD sl.If I had my time again I would maybe just have bought a set of stiffer shoes and stuck with the SPDs, they are definitely easier to get in an out of if you are stopping at lights but then again I don’t race…
notfastenough
I have Speedplays and swear
I have Speedplays and swear by them. Some find the force required to engage a bit heavy but I have 2 pairs and have no problems with either. As regards maintenance, every 6 months I squirt a bit of bearing grease into the grease port, and wipe off the old dirty stuff that comes out of the other side. I also squeeze a couple of drops of dry lube onto the cleats (since these, rather than the pedals, have the spring-loaded parts) every few rides. Thats it, it really isnt a hassle.However, you do state that you’ve already bought the SPD pedals. I think SPD adapter kits are available for the 3-hole bolt pattern on most shoes.
Shades
I use SPDs (Shimano M520
I use SPDs (Shimano M520 pedals) with Touring Shoes (Shimano RT32, but plenty of other options). Look like road shoes but have recessed cleats and you can walk around in them reasonably well without feeling you’re going to twist your ankle. Really good bit of LBS advice as I was all set to buy road shoes/cleats. Saw a interesting custom built carbon road bike the other day with disc brakes and geared up for climbing. It had Crank Brothers Candy 2 pedals on it which looked quite smart.parksey
The Shimano R088 shoes I wear
The Shimano R088 shoes I wear can take both 2-bolt and 3-bolt cleats, but I think you need to use a little adaptor if you are wearing them with 2-bolt SPD cleats (I use SPD-SL so can’t confirm for definite).MarcMyWords
Couple of great shouts there
Couple of great shouts there and I have read a lot of good things about Speedplay pedals. I think I’ve been a bit put off by the price in the past and I hear they take a lot of maintaining?Yorkshie Whippet
Speedplay X-series or light
Speedplay X-series or light action maybe better than Zeros.therevokid
Speedplay are double sided
Speedplay are double sided … 🙂 -
