- This topic has 63 replies, 31 voices, and was last updated 12 years, 4 months ago by
Midas98.
February 26, 2014 at 1:57 pm #20808
Stumps
Ladies and Gents, i currently have Shimano Tiagra fitted to my bike and i’m looking to upgrade the groupset as its getting a bit worn.
Now i’m no genius when it comes to groupsets and i’m more inclined to pick one that looks good on my bike rather than going into the in’s and out’s of specifications etc.
So having said that i’ve decided to go for either the Ultegra 6800 or the Campag Athena. Both look completely different but i’m drawn towards the Campag as i can get it in black which matches my frame, a minor point i know.
What i’m after from you lovely people is your thoughts on which one is best or which one to totally avoid. Both are similar priced at the £500+ mark.
Cheers.
sorebones
ajmarshal1 wrote:DanTe wrote:
ajmarshal1 wrote:DanTe wrote:Campag costs more. On Merlin Cycles site for instance the third tier Chorus crankset is the same price as a Dura Ace.That’s because Chorus is easily on a par with Dura Ace. It may be Campagnolo’s third tier but it’s not industry standard third tier.
That’s hilarious, and utter nonsense!
My last 3 bikes have had Campag Chorus, Campag Super Record and Shimano Ultegra 6800, so I am in a reasonable position to judge. All three are excellent groupsets of course, these days there are no bad groupsets once you reach 105 or Veloce. What you get as you go up the rankings is lighter weight and crisper shifting.
Chorus is great – looks terrific and functions well. However, having ridden both, I would take Ultegra 6800 every time. The shifts are much lighter and feel more precise, really minimal effort. The front mech is a joy to use, again lighter than Chorus, and with 2 trim positions it always runs quietly across the gears.
I laugh at the notion that somehow you are going to brake at the same time as shifting if you use Shimano – you get use to the difference in lever action in a ride or two. What you won’t miss is the thumb shifting button on Campag levers, personally I found it felt awkward having changed to Shimano, but that’s personal preference of course.
You cannot state that one groupset is better than another, it’s all subjective. Ultegra 6800 is extraordinarily good though, and great value for money.
ajmarshal1
DanTe wrote: Campag costs
The answer to the OP is Campy, always.
DanTe
All I know is that Athena
All I know is that Athena bearings are very awkward to service.
There’s the price to consider, Campag costs more. On Merlin Cycles site for instance the third tier Chorus crankset is the same price as a Dura Ace.
I would go Ultegra but I don’t like the long push across on the front shift and I hate the noise this long drawn out process makes if the derailleur is covered in grit and road crud, cringe everytime.Nick T
Chorus, Record and Super
Chorus, Record and Super Record are all the same groupset essentially, just at different weights. record gains you better bearings, hollow crank arms, bearings instead of bushings in the shifters and brakes and a bit more carbon over Chorus, and Super Record adds more carbon, better still bearings and a titanium axle.Chorus is on par with Dura Ace more or less, the other two are a step up provided Campag is your bag. None of the shifters are as user serviceable as before so don’t let that be a factor in your buying decision.
The only thing Athena gives away to the top 3 is a slightly inferior thumb shifter and a less friendly crankset when you want to remove it.
pirnie
Nick T wrote:Reasons I use
Nick T wrote:Reasons I use Campag:I can access the thumb shifter while on the tops with my little finger.
Nice to know it’s not just me that does this!!
I have Athena (the older Ultrashift version) and it’s great. But then I’m sure Ultegra is too. At the end of the day it’s a personal preference as to what you prefer. (Unless it’s an Italian frame and then Campag is compulsory 👿 )
Flying Scot
If you intend keeping it,
If you intend keeping it, Campag is the better option as you can have the shifters rebuilt, as they still do parts, a lot of Shimano stuff is throw away, it’s not designed to be rebuilt.Campag cassettes tend to be expensive, but are usually stocked in the way you want them, unlike shimano which are cheaper and more interchangeable, but not as many genuine shimano options.
Campag is designed to be a more positive shift, which some people don’t like, they prefer the lighter touch of shimano.
All 3 (including SRAM) work flawlessly most of the time, but unfortunately the first to wear out is proving to be SRAM, then Shimano, then Campag.
Also I would have athena and Ultegra about equal, Chorus slightly higher, with Record equalling dura ace and super record for posers……
Nick T
I’ve got some Zondas as well,
I’ve got some Zondas as well, they’re decent. Stiff, solid, hard wearing. Not too heavy. Great for every day riding, broadly equivalent to Fulcrum R3s.Nick T
The
Reasons I use Campag:The brake levers are just brake levers and don’t move sideways.
The front shifting.
The hoods feel more comfortable in my hands.
The brake levers are a nicer shape for use on the hoods and drops.
The front shifting.
The thumb shifter on Chorus and up can go up to 5 clicks instead of releasing between each one.
The front shifting.
I can double shift both thumb levers and be in a roughly equivalent inner ring/rear cog combo to what I was in before, instantly.
And finally, the front shifting is so nice compared to the old Shimano group I used to use.Just try riding it and see if you like the feel of it – it’s no less durable or more expensive to maintain than a Shimano group, unless you intend on buying yourself a load of new tools to maintain it with and even then it’s not a massive outlay.
Craig0605
I have ultegra 6800 and it’s
I have ultegra 6800 and it’s so smooth and amzing to use. I love how responsive the gear shift is without being clunky.
Stumps
Thanks folks, as for the
Thanks folks, as for the wheels i was going to get whatever fitted the groupset. I like the look of the Campagnolo Zonda Clincher Wheelset which you can get through Wiggle fitted with either a Campag or Shimano freehub so its good for both groupsets i believe.My head says Shimano whereas my heart says Campag. Decisions decisions 😕
allezrider
They’re now both 11 speed,
They’re now both 11 speed, although Campag has had theirs out for 3-4 years so should have sorted any minor niggles. It probably comes down to the wheels – if you are upgrading those too going across to Campag is feasible. If you are retaining your current wheels you’ll need to go down the Shimano route as the Campag cassette won’t fit. Having used both Campag and Shimano I prefer Campag – it has a more positive feel and you don’t swing the brake lever to change gear. That said maintaining Campag tends to be more expensive than Shimano. If you are going to use it through all weathers go Shimano, if its a ‘best’ bike I’d lean towards Campag.
mike the bike
Some things in life defy
Some things in life defy rational explanation but are, nevertheless, important. The woman you love, the book you have read three times, the taste of cold Guinness on a summer Sunday, each the result of subjective assessment that ignores any attempt at rational analysis.
And so it is in the eternal Campagnolo/Shimano debate. If you have to ask the question, you will never understand the answer.
mrmo
What wheels do you have, what
What wheels do you have, what wheels do you intend to get.Campag uses a specific freehub, although you may be able to get something bodged. 11spd Shimano also uses a specific pattern.
I don’t think either is bad, well I think SRAM is overpriced tat but anyway….
If you can try the levers see if you prefer the shapes. I am using old Campag and do like the shape of the new campag hoods far more than new shimano.I just find the reach to the brake levers nicer with Campagnolo as well
Fringe
The shimano 6800 requires an
The shimano 6800 requires an 11 speed compatible freewheel, think I’m right in saying that Mavic wheels are okay but some other makes are not so you may need to get a new rear hub with 11sp freewheel (don’t think you can just replace the freewheel on a 10sp hub either..but I could be wrong).andylul
I’ve had Athena for two years
I’ve had Athena for two years nearly and only just changed the chain and BB Cups (rode it all through winter – twice)I like the thumbshift – I find it’s the easiest way to downshift on the drops.
The carbon cranks look stunning, too. The whole group set, IMHO, is better looking than Shimano or (boak) SRAM – and agree with notfastenough. If you want a Toyota, get Shimano 🙂
