Techniques… For riding up hills
  • #31497
    Brooksy1882
    Spinning Vs Grinding?
    Is this basically down to individual preference? I do like the up and out the seat(although more tiring) using a 52 front ring and possibly slightly crossing my chain being on a 25 on the rear, bad days all the way across to my biggest being a 28.
    This has put me in contention for those damn Strava segments but clearly there are faster ways to my lift the knees dragging pedals into rotation. I had thought midway of dropping into the smaller front ring but knocking it down under load, can’t seeing it being a sensible idea and risking jamming it? ??‍♂️
    Is this then pick a suitable gear at the bottom that will get me to the top, even if I initially spin like crazy being seated before getting out the saddle to grind?
    Not even mentioned about going into the red here too. How much of a killer is that!! ??
Viewing 15 replies - 1 through 15 (of 16 total)
  • #977653
    I’m definitely a spinner with
    I’m definitely a spinner with the exception of little ramps where I’ll pop ups for a few pedal strokes to get the extra oomph and then sit down again.
    There are pitfalls with spinning too much though – you start spending energy on moving your legs around rather than actually moving the pedals, if that makes sense, and if you never really put any pressure through the pedals you end up with great lungs and great muscular reaction, but no strength.  As with all things – need a bit of both!
    #977651
    OnYerBike
    As I understand it, the most
    As I understand it, the most efficient way to climb is to let your gears do all the work. Ride just as you would on the flat – i.e. seated, and use your gears to stick to your normal cadence. This might include shifting up/down as the gradient fluctuates.
    You can get a bit more raw power by standing up and using a slightly harder gear, but it won’t be as efficient so it’s hard to keep up for long and you’ll burn yourself out if you try to do it too much.
    #977649
    Toad OTM
    I think it depends on the
    I think it depends on the length of the climb.  If it’s just a ninety second to two minute rise, standing and using momentum to stay on top of a big gear gets good results for me.  It allows me to stay at a far higher power than would otherwise be sustainable.  With four to ten minute climbs, I tend to use a mix of both seated and standing but stand more where the gradient inreases.  Anything longer is predominatly seated for me with a bit of standing for stretching or to quicken the pace when it’s less steep.
    What really helps is getting to know a climb and what gears work best where and when best to change them or where best to just use bigger gears and muscle your way through a section.
    #977647
    Daveyraveygravey
    I’ve read recently that
    I’ve read recently that “spinning is more efficient” is more for the pros, more for people doing long hard rides, day after day, more about recovery and being able to go out and do it again the next day.
    My last bike had a 53-39 with a 23-12 cassette, and I noticed all my friends on long hills who could spin would ride away from me whilst I was standing and hauling on the bars.  When the cassette wore out, I replaced it with a 25-12, and noticed they weren’t getting away as quickly, and then when I got a 27-12 I was almost able to hang on.
    I think you should make use of all the gears you have, and use them efficiently.  It’s a balance between hanging on to momentum, and not bogging down.  If you shift under load, you’re more at risk of something going wrong mechanically, which can also cause you to crash.
    #977645
    kil0ran
    Sit and spin on the roads,
    Sit and spin on the roads, tend to stand and climb offroad
    If it’s a very short hard effort I’ll stand when road riding but that’s more to do with not shifting than anything else.
    I know you shouldn’t shift under power but I do it and I’m a big heavy rider. It’s all in the timing, just very briefly soft pedalling whilst it shifts, and only dumping one gear at a time.
    #977643
    I’m more of a stander, but I
    I’m more of a stander, but I’m trying to train myself to remain seated going up hills as it should hopefully be more efficient. For short hills it’s more fun to just stand and stomp your way up them but with longer hills I end up slowly stomping which ends up being disappointingly slow.
    One advantage to switching between spinning and stomping is that you’re putting strain on different parts of your muscles so it’s almost like having a rest.
    #977641
    dave atkinson
    I generally don’t stand up
    I generally don’t stand up for long periods when i’m climbing outdoors, but i find it much easier on the turbo to stand, not sure why. it’s generally accepted that seated and spinning is the more efficient way to climb overall, but there’s a lot of personal preference in the mix too, which is why you’ll see pros that do both.
    #977639
    Drinfinity
    Sit and spin for me, with
    Sit and spin for me, with properly low gears.
    #977637
    Steve K
      Having a good day, I guess.
    laugh  Having a good day, I guess.
    #977635
    But how did you get up that
    But how did you get up that hill in the first place?
    #977633
    Steve K
    This is definitely true for
    This is definitely true for me. Which is also why, however much I’m struggling, I can always make it up a hill I’ve made it up before, because my brain knows I can do it. However, on a different hill with exactly the same characteristics, I might give up and push.
    #977631
    Awavey
    weird thing is Ive never got
    weird thing is Ive never got the hang of pedalling whilst standing up, it just feels wrong like Im not keeping balance on the bike properly which inevitably leads to a foot down stop moment. so I always spin though fortunately there arent too many hills around where I live as really dont like hills much 🙂
    #977629
    Sitting and spinning is more
    Sitting and spinning is more efficient, but standing is more natural – sitting over longer hills definitely gets me faster times generally – pretty intuitive I guess really, less rocking from side to side and wasted energy standing.
    There are very few hills with consistent gradients in the UK, I’d certainly start any in the smaller front ring (36 or whatever it is on your bike), and just switch to a bigger cog on the cassette as the incline increases
    #977627
    Sometimes, being in the
    Sometimes, being in the correct mindset can help you up the hills.
    If you think you’re going stop part way up the hill and walk the rest. You’re more likely to fail, than if you’re absolutely determined to reach the top.
    Think of your legs like some massive steam engine powering the wheels, and not an AAA battery powering a weedy electric motor ?
    #977625
    check12
    Pace yourself, first half
    Pace yourself, first half easier second half harder
