- This topic has 7 replies, 6 voices, and was last updated 6 years, 4 months ago by .
Hi all,
I managed to damage my rear derailleur and thought it was just the lower plates which i replaced with brand new items but it appears the whole assembly has been twisted although I cannot see any damage and it indexes perfectly. I’ve checked the hanger using a straight edge and measurements back to the wheel and it’s fine.
When you look from the back of the bike the lower jockey wheel is 5mm to the right compare to the upper (which is slightly angles) so when in a small gear the chain jumps off the jockey wheel at the bottom and when in a hi gear it won’t go into the smallest sprocket you can index one of the extremes out but it makes the other far worse. I also put a none di2 derailleur on it just to check visually i wasn’t going barmy.
I’m all out of ideas so think it’s time I ordered a new one but I can’t find any new stock has anyone seen any? I don’t really want to go to ebay for a used item as they are not cheap and if somethings wrong i don’t want the drama.
