- This topic has 3 replies, 4 voices, and was last updated 5 years, 2 months ago by .
At weekend I removed the nameplate screw on left Shimano RS505 shifter to inspect the cable guide. Shifting was a little bit sketchy and have had experience with cable cutting through the guide (and shifter housing!) on a previous set of these shifters (https://forum.bikeradar.com/discussion/13089841/rs505-cable-guides-a-cautionary-tale)
When I came to re-attach the nameplate, the litte screws that hold it in place just wouldn’t bite. I’ve removed the nameplate on the opposite side and tried those screws and still wouldn’t work. Managed to fit the screws without nameplate in place, so thinking the last mm or so of the housing might have been stripped.
Especially annoying seeing as this is the first time I’ve removed the nameplate since they were fitted in Dec 19.
Nameplate in question – https://www.sjscycles.co.uk/gear-spares/shimano-strs505-name-plate-left-hand-y03m98010/
What are my options? Slightly longer screws (what size would I need)? Carefully drill out some of the nameplate material where the screws sit?
I had planned on replacing these down the line with R7020 because of my previous problems, but looking at over £500 for shifters and calipers which is a no go!!!
Any help much appreciated, cheers
