- This topic has 13 replies, 7 voices, and was last updated 6 years, 4 months ago by .
New to the forum and tubeless wheels so go easy…
Originally bought a pair of mavic cosmic exalith clinchers but they were damaged so ended up with a pair of their newer cosmic UST wheels and am having trouble with a rim that just won’t seem to seal and it’s doing my head in as I can’t figure out what the cause is.
Background:
Wheels came taped and with tyres already seated to the rim. Set them up as instructed, no apparent issues sealing at the time but front tyre keeps losing pressure – a couple of times overnight and more recently on a ride, although not all the way flat. Weirdly, they have been fine on several 100+km rides. Pressure loss appeared to be coming from the valve area as sealant was bubbling there, suggesting valve or tape issues. After the pressure loss on the ride I unseated the tyre to check the tape which looked a bit messy (sealant on the underside of tape, tape peeling up in places) so I took the whole thing off and retaped the rim (2x round) with stans tape, pumped up with tube and left for a few hours after which time I was pretty happy with how the tape was looking.Current situation
Decided to test without sealant, allowing me to check for any issues with the seal without worrying about the mess of sealant if I had to take the tyre off. However, I’ve had no luck getting the tyre to stay up. There’s no issue with the bead or inflating the tyre, the Mavic UST system clearly works well here as I can get the trye on and off without levers, and inflate it easily with a standard track pump. I pump the tyre up successfully to its stated max of 87psi and can just about hear air escaping near the valve. Have tried the following to get it to stop:– dipped valve plug in sealant before seating
– put grease around valve plug
– put an extra o ring between the valve plug and rim tape
– put old bit of inner tube between valve plug and rim tape
– changed valve core
– retaped and re-cut tape over valve areabut nothing has stopped the tyre losing air over the course of about 20 mins. It looks as though there’s a tiny 1mm or so tear in the rim tape on the edge of the valve hole (not helped by inserting and removing the valve several times) but it would be fully covered when the valve is inserted. Elsewhere the tape still looks perfectly in place right across the rim bed and there’s no signs of holes at any of the spoke areas. When faced with the weigh up between adding sealant and hoping for the best or putting an inner tube in so I can keep riding guaranteed, I went for the latter option. I would love to get this working tubeless as the feel on the road and puncture repair is great, and the system clearly can work as the rear has kept pressure for a couple of weeks without issue.
So my questions to anyone with experience in this area are:
– What is the likelihood that this will sort itself out if i put sealant in and shake in order to cover the leaking valve area
– Am I missing something with the valve seal or otherwise with the tape (I know any leak from the tape will show up through the valve hole in the inside of the rim, and this may have been what was happening with the old tape, but I’m pretty sure air is now getting out through the valve area itself as it’s faintly audible)
– Is retaping the whole rim and getting a cleaner valve hole in the tape the only real solution?Thanks for your help. And fair enough if you’re just commenting to tell me that road tubeless is a waste of time, I suppose it’s deserved but you’re still an ass…
Henry
