Road rash treatment
  • This topic has 10 replies, 6 voices, and was last updated 3 years ago by Daveyraveygravey.
  • #1018761
    Daveyraveygravey
    Great info!  Just recovering
    Great info!  Just recovering from a nasty front wheel slide out on green chalk a couple of weeks ago, wish I had known this then!
    #1018759
    kil0ran
    Mepore is also good for
    Mepore is also good for oozing wounds and comes in large sizes.
    #1018757
    kil0ran
    +1 for Tegaderm (or as it’s
    +1 for Tegaderm (or as it’s called in our house Tigger Derm)
    Sticks, stays stuck, comes off easily when done, no issues with ripping hair out if that applies to you – find an edge and roll it off slowly.
    In the first day or so when it’s wet go with something like a Xupad under either a conforming bandage or tubular bandage (referred to as yellow line or blue line in the trade) – assuming you’re dressing a limb. The Xupad won’t stick to the scabs and provides a layer of protection.
    In an emergency a heavy flow sanitary towel can work as a dressing, as can a disposable nappy.
    #1018755
    zedthegreat
    Thanks!
    Thanks!
    #1018747
    zedthegreat
    I did consider that!
    I did consider that! But as you say a bit expensive all in.
    #1018753
    That’s what I recall. It
    That’s what I recall. It comes with instructions which are pretty good. You need to get it stuck on all around (adhesive is only around the perimeter) or some of the liquid might drip out. I think I managed to keep them on for about five days.
    They don’t recommend putting antibiotic cream under, as any grease that gets to where the sticky will be will stop it from adhering properly.
    #1018751
    What is it the pros put on
    What is it the pros put on there, held in place with these mesh thingies?
    #1018749
    zedthegreat
    Cheers – just to be clear don
    Cheers – just to be clear don’t put anything under? Just clean then slap on?
    #1018745
    Jimmy Ray Will
    What I’ve done is cut up the
    What I’ve done is cut up the larger Boots patches so that I can lay multiple patches alongside each other. Sort of like roofing slates…
    Works well, but it’s not exactly a cheap solution!
    Skills you never thoughts you’d need hey?
    #1018743
    I don’t know if you can get
    I don’t know if you can get them in the UK, but 3M Tegaderm come in very large sizes and work great. You just clean the wound well, carefully apply one, and leave it on for a week or so. Much less pain and scarring.
