- This topic has 3 replies, 2 voices, and was last updated 5 years, 10 months ago by .
I wonder if you can advise me what can be done. I bought a new wheelset for my Cannondale Synapse. I wanted to have a tubeless setup. I didn’t research it much and left the wheels in a garage for over a year. In hindsight I should have checked it more thoroughly straight away and actually choose other wheels. Recently, I finally decided to fit the new wheelset.
First it turned out that I need to buy new disk brake rotors as the new wheels have a centre lock system as opposed to 6-bolt as in the old wheel. Done.
Then I realised that the new wheels need a 12-mm through axle (not a 5mm qr skewer as the old wheel and the bike frame needs)
I googled a bit into adapters from 12mm through axles to 5mm qr skewers and found one (Incidently, most QR adapters seem to 9mm skewers not 5mm.
So I got the adapters:
The problem is that when I insert the adapters, the rear wheel will not fit in the frame. The adapter, due to its build, makes it impossible for the rear wheel to fit in. The rear forks seem not wide enough ( not spread apart sufficiently) for the wheel to get in. It’s a question of millimetres but it won’t. It’s a carbon frame.
Two things that I can think of:
– try to grind the adapters sides a bit for it to fit in
– as I couldn’t find any other 12mm to 9mm adapters, I could research a 12 to 9mm adapters and get new 9mm QR skewers. What’s the difference between 9 and 5mm? Most of the adapters come for 9mm ones.
Any other ideas?
It’s been almost 18 months since I bought the wheels so I cannot return them. The wheels are Mavic Cosmic Elite UST Disc Wheelset 2019.
