Are 105 Hydro Brakes Disappointing?
  • This topic has 26 replies, 15 voices, and was last updated 4 years ago by IanMSpencer.
  • #32310
    Willdb
    Is it just me or are 105 hydro brakes not really upto much? I’m certainly not impressed with mine, especially when compared to my other bike with what I believe are the lower end sram apex hydros, which are twice as powerful, don’t ever squeal, done twice the mileage, seen all weathers and have had no maintenance at all.. By contrast my pampered 105 system has seen no bad weather, been fully bled, had new ceramic pads and ultegra rotors fitted and they still feel like cane operated single piston brakes.. I’m thinking of selling it because of this inferior characteristic..it makes me think that shimano groupsets are all marketing bluster… Any thoughts anyone?
Viewing 15 replies - 1 through 15 (of 26 total)
  • #1007549
    Good point. I think the R785
    Good point. I think the R785 was the Mk1 attempt at road bikes and they soon came up with the revised variant where they updated pad design.  Since then the road bike pads have diverged to their own variant which has remained consistent. When I did repairs, tracking pads was a nightmare and given you could see there was little functional difference, it was really annoying. Nearly as bad as gear hangers – another one with ridiculously pointless variation.
    Quite a useful chart here:
    https://shimanobikes-nz.prontoavenue.biz/ts1570079501/attachments/Page/20/Disc%20Brake%20Pad%20Compatibility%20Chart.pdf
    #1007547
    mark1a
    Although I have one road bike
    Although I have one road bike with R785 calipers and takes the J type rather than L type pad.
    #1007545
    Shimano have only one fit of
    Shimano have only one fit of “road” pads, so they are all interchangeable, including with GRX, though they have made several variants of that fit, their coding covers the brake material and whether they are finned, but as these codes are intermixed with their MTB and hybrid series it is quite baffling.
    You don’t need to have finned just because that’s what was delivered either, and unless you regularly ride somewhere needing a lot of steep braking descents, the fins aren’t going to do anything for you.
    #1007543
    Steve K
    It’s the higher end rotors (including Ultegra) that are rated for use with metallic and resin pads. The cheaper ones which presumably use softer alloys are specified for resin pads only as otherwise the rotors would wear too quickly and fail quicker than a hollow-bonded crank.
    High end rotors – good
    High end cranks – bad.
    #1007541
    Cristox wrote:
    Cristox wrote:
    huntswheelers wrote:
    For those rotors you need resin pads…. if you want mixed pads or different pads to Resin then get some other rotors…
    This is complete nonsense. The Ultegra rotors are fine with metallic and resin pads.
    #1007539
    Cristox
    #1007537
    huntswheelers
    For those rotors you need resin pads…. if you want mixed pads or different pads to Resin then get some other rotors…. When customers come with similar issues, I pop them on Prime rotors from Wiggle and semi metallic pads.. never had any complaints… and…always Shimano disc brakes…. as for Sram… they have other issues…lol
    #1007535
    mark1a
    They should both be Shimano L
    They should both be Shimano L type, yes.
    #1007533
    Wingguy
    Any Ice-Tech rotors are fine
    Any Ice-Tech rotors are fine for sintered or ceramic pads. All the resin only ones are much cheaper options.
    #1007531
    Willdb
    I’ll check that..my rotors
    I’ll check that..my rotors are rt800 icetech… I’m ordering some resin regardless
    #1007529
    Willdb
    I think you maybe right.. I
    I think you maybe right.. I think if the ceramic pads are cool then the bite will be reduced.. Would you know if R8070 pads fit R7020 callipers?
    #1007527
    Willdb
    Discs and pads are new… I
    Discs and pads are new… I think maybe the ceramic pads could be the issue?
    #1007525
    Jimmy Ray Will
    As other comments, my first
    As other comments, my first thought is why do you have the ceramic pads?
    #1007523
    Wingguy
    Those are the cheapy cheapy
    Those are the cheapy cheapy rotors. Anything 6x series or above is fine for any compound (like the sintered pads that Shimano themselves make). Equivalent series rotors to 105 or Tiagra will be fine, though sometimes brands will cheap out and spec a bottom end resin only rotor as OE on an otherwise 105 spec bike.
    #1007521
    Willdb
    Steve K wrote:
    Steve K wrote:
    Which Ribble bike do you have, BTW?
    It’s a carbon SL Disc
