- This topic has 4 replies, 4 voices, and was last updated 7 years, 2 months ago by .
My son’s Campag Veloce drive side crank has all the symptoms of the pedal axle thread starting to give way – to the extent that the pedal has sometimes unscrews entirely, still attached to the shoe. I’m trying to work out what to do.
A friend has passed on some Chorus carbon cranks (FC9-CEO-40C, both cranks and rings) of the right length (170), but these are Ultra Torque, and the Veloce on the bike now is Power Torque. Is that a problem?
Ebay has new old stock Record 170mm drive side cranks at £25,but again, Ultra Torque, and this would mean different cranks each side. Is that a problem (small weight mismatch I guess but surely immaterial given the weight of rings)?
My guess is that if that either of these fit, it will be cheaper than any helicoil-type solution and a much more straightforward job for the LBS. So how do I find out if they will work with the BB?
The Veloce chainset is of uncertain vintage but the crank is labelled FC11 VLB040. My son isn’t the first owner of the bike and the bike probably isn’t the first to have had it either. I can’t see any BCD marked on it but there are some marketing speak things – Power Torque is the main one.
Any wisdom from all you smart people about where to look for compatibility?
Thanks in advance!
