Campag Zonda shimano free hub
  • This topic has 9 replies, 6 voices, and was last updated 7 years ago by Nick T.
  • #29951
    rob39
    Hi my shimano free hub has given up the ghost on my zonda’s (bought 2015) Anyone recommend a replacement, CRC told me they don’t stock these anymore will the current fulcrum ones be compatible. 9/10/11sp
  • #946857
    Nick T
    https://www.bike24.com
    https://www.bike24.com/p251686.html
    your LBS should be able to replace the worn bearing in about 15 minutes though.
    #946855
    rob39
    Some of the vids I’m watching
    Some of the vids I’m watching requires a bearing press? To get the bearings back in the freehub? Some of the prices I’d be easier just getting a new freehub. Anyone know where a compatible freehub for a Campag wheel with Shimano Cassette can be sort.
    #946853
    Nick T
    Should be “6803 2rs” bearings
    Should be “6803 2rs” bearings. There’s a rentention ring that makes it tricky to tap the cartridge out, circlip pliers are handy if you have them.
    #946851
    mike the bike
    rob39 wrote:
    rob39 wrote:
    The shell does look OK. Anyone point me in the right direction for bearings? Any video recommendations
    If you remove the bearings ( I’d use a length of wooden dowel rather than a screwdriver ) they will probably have some numbers on them.  These might be a commonly used part number ( ac 3544 or similar ) or possibly measurements / angles particular to these bearings.
    You can then look at kineticbikebearings.com to track down the replacements.  If yours don’t appear on their website, give them a ring and they will sort you out.
    Best of luck.
    Other bearing suppliers are available, as they say on the BBC, I have no connection with any of them, except as an occasional customer.
    #946849
    Welsh boy
    Rob, I am sitting on the side
    Rob, I am sitting on the side of the road just outside Rambouillet waiting for the Tour de France to pass ( just thought that I would put that in for the fun of it) but when I get back home I will see what info I can get for you if no one else has already done it
    #946847
    rob39
    #946845
    srchar
    I would change the bearings
    I would change the bearings even if a new freehub was easy to get hold of. Fifty quid is robbery.
    #946843
    Welsh boy
    From experience I would think
    From experience I would think that it is just the outside sealed bearing which has gone. Tap it out with a small hammer and screwdriver and see if it is gone. It is a readily available size and should cost about £5 for a new one. I have had to change a couple of them, had two original ones fail in a few thousand miles, the replacements have lasted much longer than that. With the price of a new freehub being around £50 it is worth a try first.
    #946841
    joeegg
    If the shell is ok isn’t it
    If the shell is ok isn’t it just possible to replace the bearings ?
