- This topic has 9 replies, 9 voices, and was last updated 7 years ago by
bikercat.
July 20, 2019 at 6:29 pm #29925
Hoggy1972
HI,
I have a short cage 105 rear mech (5700) and a Deore XT long cage rear mech. Can i swap the long cage from the XT onto the 105? will it fit?
bikercat
Not answering the question I
Not answering the question I know, but SJS cycles are fantastic for those hard to source parts.
jacknorell
Collins wrote:
Collins wrote:You can buy a long arm for the derailier and swap it out, not sure where from though as the bike shop did mine.
SJS cycles should have the partsCollins
Welsh boy
Dingaling wrote:These look just like wolftooth and are cheaper, as Welsh boy wrote:Keep looking, they are on there for less than £2 now
Dingaling
Welsh boy
Chris Hayes wrote:I’ve just bought a Wolf Tooth Road Link to faciliate a larger cassette. It’s pretty expensive for what it is – a drop hanger for derailleur – but it’s cheaper than a new derailleur and you don’t have to break your chain (which in old money means a new one). They’re GBP 23 on AMZN Prime (an outlet I rarely use for bike parts, but few bike shops stock them – not even mine, which is Condor).I bought a generic extender off eBay for less than £5 which works fine, I dont see how a Wolftooth can be any different or better. Just search Derailleur extender and take your pick.
Chris Hayes
Good answer from Woldsman,
Good answer from Woldsman, another thing is what’s the largest sprocket you’re aiming to use, the 6700 SS I know for definite had a Shimano stated 30T max. IF the 5700SS has same I reckon you’d be able to do 32T with the usual B tension screw done right in. Obvs if you’re going bigger then that’s probably not doable.
currently I run an Ultegra 6800 SS with a 32T and it was only designed for a 28T
Any of the 7/8/9 speed MTB mechs would work if your XT isn’t 9 speed era.
Woldsman
Assuming your XT is 9 speed
Assuming your XT is 9 speed you can swap the entire mech to replace the 10 speed 105 rear derailleur. Do be aware that some XT models (eg M772) don’t have a barrel adjuster, so you may need to fit an inline one (eg Jagwire).
Note: you cannot simply fit a 10 speed XT to a bike that previously ran a road 10 speed system such as 105 as the shift ratio is different.
