Canyon Aerocockpit, CP10 vs H36, confusion
  • #29538
    JensLeander
    Hi!
    Yesterday I unboxed my new Canyon Ultimate CF SL 8.0 2019. When I couldn’t mount my ordered Garmin Mount I discovered that they mounted the wrong cockpit on the bike, I think.
    On the website it says the bike should be equipped with a CP10 Aerocockpit, but I have a H36 mounted.
    Question is now which is better of the two cockpits? Have I been lucky or should I complain?
    I am struggling to find much information about the CP10 cockpit.
    Hope someone know the difference between the two and which is lighter/faster/better
    /Jens
  • #939661
    JensLeander
    Thank you for the replys. Yes
    Thank you for the replys. Yes I also found that the CP10 is lighter, (70-80g). But why does the most expensive Canyon Aeroad 2019 model have the H36 then? And also Rafael Valls on his World Tour Ultimate Canyon?
    #939659
    AlsoSomniloquism
    Supposed to be lighter, but
    Supposed to be lighter, but only seems to be on the “cheaper” frames. sad (although they could be newer ones).
    I don’t like the new Canyon product pages as they are alot less detail orientated then the old ones. They used to have the weight, dimensions, even tooth increments of the cassette and all included links to the manufacturers website and documentation. Now most of that is gone.
    #939657
    BobbyG
    Looks like the new CP10 is
    Looks like the new CP10 is lighter…
    https://weightweenies.starbike.com/forum/viewtopic.php?t=83565&start=2280
    #939655
    generationally
    There is some info about the
    There is some info about the CP10 if you check the product page for the Ultimate CF SL Disc Frameset.
    It says that “At a mere 320g, it is lighter than its predecessor”.
    Not sure if it helps you…
