- This topic has 17 replies, 14 voices, and was last updated 7 years, 10 months ago by
fukawitribe.
January 9, 2019 at 12:36 pm #29270
slowclimb
Hello Zwifters!
I’m having a bit of a nightmare…
I’ve been using Zwift for about 6 weeks and it’s been great. But over the last week it’s started crashing almost every ride, I haven’t changed anything – same laptop, same turbo, same ANT+ dongle, same WiFi network…everything.
I got 20ishK into a ride last night and it crashed and about 17 this morning and the same thing.
I can’t work out why at all, and as you can imagine I’m getting very little sympathy at home! It’s a real first wild issue but I’m sure you chaps at least will understand how annoying it is!
Any ideas? -
fukawitribe
Jetmans Dad wrote:pastyfacepaddy wrote:Companion app on Android A3 did refuse to show the map although everything else worked fine i.e. dashboard, zwifters etc.There are some issues on the Companion app maps when using the new worlds (Innsbruck and New York). My companion app did exactly that on stage 2 of the Tour de Zwift (NYC) and when I posted to the Zwift forums about it, it appears it is quite a widespread issue.
I was avised to update the app to the latest version (which it already was) and make sure everything was properly closed and reopened, but made no difference when I did a short ride in NYC last week.
Will be interesting to see whether there is a map in Innsbruck this evening for stage 7.
FWIW just done stage 7 and the map is missing again on the companion app – Samsung J5/6 (on Android 7.1.1), Zwift Companion App v 3.0.3 (527). It’s been a pain for a while, no indication/confirmation of reproducing it from Zwift yet that I know of.
Jetmans Dad
Sniffer
FlyingPenguin wrote:So, after riding stage 4 of the TdZ today, it seems they have disabled some features during group rides (rankings, chat), presumably to lessen server load.Worth trying again and seeing if you have better luck? Seemed pretty stable to me.
Noticed the ranking had gone. Kind of missed it last night.
FlyingPenguin
arckuk
In normal use, Zwift
In normal use, Zwift communicates the position of the nearest 200(?) riders, which may be rendered on your device’s screen. This communication is not at a huge data rate – certainly not enough to overload the average broadband connection. When less than great home wi-fi is incorporated into the mix, there may be additional bandwidth resctrictions and/or latency between that data being sent and the user receiving it. Bear in mind that the user also communicates their power, heart rate, cadence, position on track?, speed(?) info back to Zwift, who then take this data and send it out to whoever has you within their 200 rider radius. ANT+/bluetooth interference and drop outs won’t help.
I don’t think the raw number crunching of this user information is actually hugely computationally expensive, and Zwift will be able to spin up multiple servers very rapidly to cope with changes in load. The distribution of this information over a variety of networks may well be more of an issue.
I don’t know what happens when rider density is really high, as in these multi-thousand user start events, but I guess you might get information on more than the default number of nearest users if they’re really close.
For the CPU and graphics card of the user’s device, rendering all these other users will cause more load, and result in a drop in frame rate. Combine this with lags between data communicated to and from the user that could result from increased local and remote processing requirements, and systems that will normally be just about usable are most likely to drop into the unusable territory.
The majority of users have a good experience in these events, it’s just that this sort of issue is most likely to raise its head in this type of event. In some cases it may be Zwift’s issue, most of the time I think users are hitting a limitation of their setup.
Basically, I think it’s more likely you’ll see these slowdowns if your CPU, GPU, Wifi, broadband or ANT+/Bluetooth signal is less than optimal. The problem for many is identifying which one is the limiting factor. Maybe Zwift could help by providing some sort of testing program, which would help point the way, until then, there’s https://zwiftalizer.com/ which is the best way to analyse log files to see if there’s anything obvious.
CXR94Di2
Set graphics to 720p and
Set graphics to 720p and ensure good internet connection. Ive had less issues now I use mobile data link at 60mb connection speed. I have a decent mid range pc with plenty of ram and good graphics, well enough to run 1080p and still be able to race in TDZ. I think there were 4000 riders on my particular event plus normal zwift users. Ive seen 10,000 users at once but dont get full crashes, just short period dropouts and it always returns without losing ride/race.
number9dream
For these recent tour stages
For these recent tour stages i’ve found the same on wi-fi but no problems with a wired connection. Seems to be a widely held view on the forums too. Also switching to the low graphics setting when doing a massive group ride seems to help.
Rapha Nadal
Ah, I had issues last night
Ah, I had issues last night with a very juddery picture and slow to update the images on the screen – ran laptop through tv intially & then just on laptop but same resuts. I thought it was just our crappy Sky broadband!
muhasib
I thought people did indoor
I thought people did indoor cycling as they wouldnt experience freezing or the chance of crashing?bfslxo
Team EPO wrote:One thing I have found that has helped with the crashes is using a router that allows you to priotise devices as I compete at home with avid streamersCan I plead ignorance & enquire how would I go about doing that?
FlyingPenguin
Actually, another possibility
Actually, another possibility, if it’s properly crashing rather than just glitching (e.g. riders dissappearing, wrong world etc), it might be worth trying to turn down the graphics settings. I can’t imagine that it’s optimised for the 2-3,000 rider groups that have been seen lately.
I suspect that there will be a number of lessons to be learned from the current tour!
Team EPO
slowclimb
Hmmm…maybe it’s not just me
Hmmm…maybe it’s not just me then
if it is a Zwift problem they need to get their capacity sorted, Minimum 12,000+ riders all at £13 a month is a lot of money and we deserve a reliable service at least!
pastyfacepaddy
Rode 21miles using the Zwift
Rode 21miles using the Zwift Windows app on Windows 8.1 (yes I know) on Monday night and no problems. Companion app on Android A3 did refuse to show the map although everything else worked fine i.e. dashboard, zwifters etc.
Turbo and pc are in the conservatory and running over wi-fi.
dave atkinson
there was over 12,000
there was over 12,000 concurrent users on there the other night which is the most i’ve ever seen. I was in a race and had issues with everyone else in the race disappearing from time to time, which didn’t exactly help with staying in a group. didn’t crash though.
