28mm tire clearance on CAAD12.
  • This topic has 7 replies, 6 voices, and was last updated 7 years ago by ibr17xvii.
  • #29027
    awesterhoff
    Hi there,
    I’m looking to put a little comfort on my bike throughout the winter and therefore I’ve been looking to buy some 28mm tires. I’m a little in doubt about the clearance, if the Cannondale CAAD12 with rim brakes, can fit 28mm tires. I’m currently riding on Bontrager Aeolus Pro 5 TLR Clinchers wheelset.
    Does anyone know or have any experience with this?
    Thanks,
    Alex
  • #928679
    ibr17xvii
    ShaunC wrote:
    ShaunC wrote:
    On a 2018, Durano 28s on Mavic Ellipse fit but you need to fit the wheel with the tyre deflated to clear the (Ultegra) rim brakes and then inflate once fitted. Also means you need to deflate the tyre if you want to remove the wheel to clean the bike.
    I’m running DT Swiss RR21 wheelset with GP4000 28’s & same situtation for me.
    Either need to deflate the tyre or wind out the barrel adjuster all the way to get the wheel through 105 brake calipers.
    #928677
    ShaunC
    #928675
    gerradferrier
    I’ve just put on some Maxxis
    I’ve just put on some Maxxis re-fuse 32mm and they run well.
    Did a 60 mile gravel ride yesterday with no issues.
    #928673
    gerradferrier
    Yep G-one speed (30mm) fits
    Yep G-one speed (30mm) fits fine.
    #928671
    MoutonDeMontagne
    Interested in this too,
    Interested in this too, anyone tried G-one speeds (30mm)?
    #928669
    AS78
    I also run 28’s on mine and
    I also run 28’s on mine and they have plenty of room.
    #928667
    ibr17xvii
    I run 28’s on my CAAD12 from
    I run 28’s on my CAAD12 from 2016 with no problems, you should be fine.
