Tubeless repair
  • This topic has 6 replies, 6 voices, and was last updated 8 years ago by AfterPeak.
  • #28863
    Cdl888
    I have a Schwalbe Pro One 28mm that picked up a decent sized cut. It sealed almost instantly allowing me to finish my ride unincumbered, but since then it’s spewed the sealant on a couple of occasions before resealing so I’m thinking I need to repair the tyre. I was planning to use standard puncture patches glued to the thoroughly cleaned inside of the tyre, but wondered if anyone had any other tried and tested suggestions?
    I’m totally sold on tubeless and would never go back to tubes before someone states the obvious!
  • #925773
    AfterPeak
    I carry these https://www
    I carry these https://www.evanscycles.com/innovations-tubeless-tyre-repair-kit-EV150146?lsft=esvt:60572-GOUKE4995068,esvq:,esvadt:999999-0-1352720-1,esvcrea:248664181826,esvplace:,esvd:m,esvtg:pla-306946372053,esvo:EV150146-NA-NA,esvaid:50080&esvt=60572-GOUKE4995068&esvq=&esvadt=999999-0-1352720-1&esvcrea=248664181826&esvplace=&esvd=m&esvtg=pla-306946372053&esvo=EV150146-NA-NA&esvaid=50080&gclid=Cj0KCQjwn4ncBRCaARIsAFD5-gUuUQoMoIF3qP0INEddkbEFQtqvLMTo-kkfvsmxY6SNfMGwyoVhS3UaAn-xEALw_wcB
    Have used one and it worked for a couple of rides then it just would not seal so patched it. No issues since. I hear gaffer tape works but never tried it.
    #925771
    Cdl888
    Thanks folks. Used a standard
    Thanks folks. Used a standard patch on the tyre and it seems to be working perfectly. Pleasantly surprised at how easy it was to set the tubeless tyre back up again with fresh sealant.
    #925769
    Spangly Shiny
    Agreed that a standard patch
    Agreed that a standard patch repair on the cleaned up inside of the tyre is good. However if superglueing the outside it is worth considering using a flexiblie cyanoacrylate such as Loctite Power Flex. Standard super glue will harden and crumble away.
    #925767
    I too have had great success
    I too have had great success with patching from the inside with a standard patch. I also fill in the cut on the outside with a decent quality super glue.
    #925765
    paulrattew
    Standard puncture patches
    Standard puncture patches should hold, but you can also get more specific products designed for the inside of the tyre, such as the Hutchinson Rep’Air kit (http://www.wiggle.co.uk/hutchinson-repair-tubeless-repair-kit/) – I’ve used these in the past with a lot of success
    #925763
    CXR94Di2
    That is the correct method
    That is the correct method for a bigger hole repair
