Smart Turbo Trainer
  • This topic has 8 replies, 5 voices, and was last updated 8 years ago by CXR94Di2.
  • #28807
    Dantfletcher
    Hi all,
    I am looking to invest in a smart Turbo trainer. I live in a first floor flat so it needs to be quiet for my neighbours below. What are the best options? I have researched lots of them but would prefer info from people who have actually used the products.
    Thanks
  • #924747
    CXR94Di2
    The two quietest Turbos are
    The two quietest Turbos are the V4 Kickr 2018, and Tacx Neo. To further aid noise suppression, use a dense foam beneath a piece of 12mm ply, same on front wheel
    #924745
    fukawitribe
    Dantfletcher wrote:
    Dantfletcher wrote:
    Budget is as cheap as possible however I know you have to pay a lot for a quiet smart trainer . I have looked at lots online but you don’t really know what they are like until you get it and try it for yourself. Thanks for the help guys
    You probably have already, but just in case these two might help with some more info (Ray Makers blog is the go-to place for trainer reviews for many, and Shane Miller has a no-nonsense approach to breaking things…)
    https://www.dcrainmaker.com/product-reviews/trainers
    https://www.youtube.com/user/gplama
    #924743
    Dantfletcher
    #924741
    fukawitribe
    The early Fluxes had a couple
    The early Fluxes had a couple of issues that resulted in quite a few returns, one problem was an externally sourced part they ended up bringing in-house, they seemed to sort those reasonably quickly though (there was still a chunk of old stock in circulation). Feedback I’ve seen is that later models were solid. The new Flux 2 looks like a monster for low speed stuff too.
    #924739
    ibr17xvii
    Maybe I was just really
    Maybe I was just really unlucky but I had 2 Fluxs break on me in quick succession. It was pretty quiet though (when it worked).
    As above it depends on your budget – Kickr Core, Kickr or Tacx Neo are probably the best in terms of noise.
    I have the V3 Kickr which has the “whine” but I don’t find it loud or off putting at all. If your drivetrain is quiet that’s all youn should really hear.
    #924737
    fukawitribe
    What sort of budget do you
    What sort of budget do you have ? The latest range of smart trainers has some incredibly quiet models but they’re still not at the cheaper end of the spectrum (although increasingly well priced). The Kickr Core is the obvious one there, although that has meant that existing quiet(ish) models are going down in price (the Elite Direto is now regularly around £ 600 for instance).
    #924735
    Dantfletcher
    That’s what I have been
    That’s what I have been looking at, just don’t want there to be too much vibration and cause the family below my flat any hassle!
    #924733
    Martyn_K
    Direct drive is the way to go
    Direct drive is the way to go. With no drum/ wheel humming they are much quieter and tend to create less vibration too.
    I can only refer to the Tacx Flux which i have in terms of absolute noise. I can use mine in the corner of our lounge/ dining room and the wife can still watch TV the other side of the room (slight increase in TV volume).
