How large a rear cassette can my bike take?
  • #28595
    Team EPO
    Hello
    I have just bought a new to me bike and it came with 28 cog rear cassette but I am used to a 34, will it fit my bike or will I need a new rear mech for the dinner plate I want on the back?
    Thanks
  • #921011
    CXR94Di2
    Chris Hayes wrote:
    I’m just switching my 53-39/25-11 for a 50-34/32-11, which requires a DT capacity of 37 – the maximum allowable with my GS6800 derailleur, but I wonder whether DT capcity is an ideal measure as you would never ride on 34/11 – infact I doubt I’d ever use anything higher than 34/25 – so well within the DT capacity; unless I’ve misunderstood something.
    For info, I have Campagnolo groupsets on my other bikes and have no issue running 53-39/29-12 on a SC derailleur.
    Your new setup is pretty much standard these, even 11-34 cassettes are specced on the newest bikes.  You’re right, that you would ever go to 34/11 small-small.  I tend not to bother with what the manufacturer says and just do a conversion and make it work.
    #921009
    Chris Hayes
    #921007
    bondirob
    A medium cage Shimano will
    A medium cage Shimano will take up to a 36 cassette but you will need to fit a longer b screw
    #921005
    700c wrote:
    700c wrote:
    Chainstay length also affects. The longer, the more tolerant it is of a wider gear range / small capacity RD. Calculators be dammed, i think you just have to use trial and error!
    I can see how chainstay length might affect the length of the chain, but I don’t see how it affects the drivetrain capacity.
    Why wouldn’t a calculator work? The derailleur has to cope with the different slack in the chain between different gears which is exactly what the drivetrain calculator works out and what the manufacturer specifies that the specific derailleur can cope with.
    #921003
    700c
    #921001
    VeloUSA
    Take a look at this Wolf
    Take a look at this Wolf Tooth RD hanger extender. Claims it can make a medium cage handle 11-36 and 11-40 cassettes.
    RoadLink
    #920999
    Here’s a very useful page wih
    Here’s a very useful page wih info about drivetrain capacity:
    https://guides.wiggle.co.uk/rear-derailleurs-buying-guide
    [difference between tooth numbers on smallest and largest chainring] + [difference between tooth numbers on smallest and largest sprocket on cassette] = drivetrain capacity
    #920997
    froze
    We would need to know the
    We would need to know the current rear derailleur’s make and model, and if it’s a short cage, medium cage or long cage.  Sometimes just make and model alone will help us to tell you if that particular model only came in one cage size.  There is a method of measuring the cage in MM which can tell us, simply measure the center of axle, of the top jockey wheel (pulley) to the center of axle of the bottom jockey wheel (pulley).  If the measurement is 50 mm it’s a short, if 74 it’s a medium, if 86 it’s a long.  Unless you have a triple I doubt you have a long cage.
