- This topic has 12 replies, 6 voices, and was last updated 8 years, 9 months ago by .
Hi all,
My new frame is in the post and I am trying to collect all the bits and plan out my build. I have come up against some issues with the Di2, though.
I wull be using RS785 shifters (Ultegra Di2 and hydraulic disks) and I would like to wire up an RS910 bar-end Junction A instead of the under-stem external type. The wiring diagram as per Shimano looks like this.
The trouble I am having is that I have no need for a wireless unit in my build (the EW111, item H in the above wiring diagram). This leaves me with an issue in connecting the cockpit side to the Junction B box. As I have only one e-tube connector on each shifter, I have to use the JC130 Y-connector cable (as per here) to link the bar-end Junction A to the off-side shifter and the circuitry in the main body of the bike (as per the wiring diagram linked earlier). My issue is length – how can I get the short cable of the JC130 into the Junction B?
JC130s come in 3 different sizes but in each case the short cable is only 50mm. Is there a Di2 MtF connector? Do I need a SM-JC40 junction box in my handlebars?
Cheers,
Eddy
