- This topic has 12 replies, 8 voices, and was last updated 9 years, 1 month ago by .
Just a quick post to say thanks to the chaps who stopped to help me on the weekend, and a little warning to others…
I’ve had a set of tyre levers in my saddle bag for as long as I remember, nothing fancy just a set of tyre levers. Following a change in the manufacturers guidelines, I’d recently switched from Conti GP4000s ii tyres (which I’ve been using on all my bikes for years), to Schwalbe S-One tyres. I managed to fit them with only a little bit of faff, tubeless tyres being made to tighter tolerances to support hookless rims; but hadn’t had cause to remove the tyres since the first fitting.
I got a puncture on Saturday (why is it always the rear wheel?), so pulled over and proceded to (attempt too) replace the inner tube. The wheels I have (Hunt) have a recess in the middle of the rim to aid getting the tyre on, without pushing the tyre into said recess you’ve got zero chance of getting it over the rim.
I spent a good 20 minutes trying to force the settled bead into the middle of the rim, trying all sorts of brute force and pushing with my tyre levers. Note this isn’t even getting the tyre over the rim at this point, it’s just trying to force the tyre into the middle channel so I can get a tyre lever underneath it to lever the tyre off.
In the end I flagged down a couple of helpful chaps who rode past. Three grown men were not able to unseat the tyre bead by hand. The saving grace was that one of them had a Park tyre lever which has a considerably narrower “wedge” end – which we were able to jam into the gap between rim and bead – which finally provided the required leverage to get the bead to un-seat.
So just a friendly warning, if you change tyres/wheels to a new brand – make sure your tooling will allow you a road-side repair!
On the off-chance they read they, many thanks to the two gents who helped a fellow cyclist on Hounds House road, you saved me a great deal of hassle.
