- This topic has 2 replies, 3 voices, and was last updated 9 years, 1 month ago by .
In March I did a major overhaul on my drive train. I replaced the Pressfit bottom bracket from a plastic to a Steel one. This has cut out a lot of noise and creaking. After this I replaced my look (Keo) pedals with new ones. I was able to narrow the noise down to the pedals by spinning with no pressure. The new ones were buttery smooth for a few weeks, but pretty soon the dread ticking of doom started again.
I admit I do take my (No.1 road) bike off-road on some gravel paths and do a lot of short sprints where I am putting quite a lot of pressure on the pedals. I think it is the side/downwards torque that causes the issue on the pedal bearings.
I have been using Look pedals for the last five years and not had much trouble with them. Initially I liked the easy of clipping in, and the large surface area means they are flat enough to be worn with trainers on an off day. Now I might be willing to forego some of these benefits if it means a quieter ride.
I have just regreased the crank screws and given the pedals a good spray with lube and it seems to have dampened things down, but not eliminated noises. Are ticking noises inevitable with other systems? I have Giro shoes with 3 holes on the bottom, am I stuck with Look?
TL:DR – Look Pedals are noisy, maintenance/replacement tips please.
