Steel bike purchase
  • This topic has 13 replies, 11 voices, and was last updated 10 years ago by John_S.
  • #26239
    sanremo
    New forum member query….
    New bike purchase on the cards.
    £1700 tops !
    Steel (of some sort) Built for commuting/audax riding.
    Looking at Condor but what else is out there which is worth looking at?
    Thanks…..
  • #877703
    John_S
    Hi sanremo,
    Hi sanremo,
    If have to agree with many of the posts above that getting yourself a nice steel frame and building it up with the exact components that you want would be a great way to go!  You’ll hopefully end up with a bike that’s just right for you and will last you years and years.  Following your message I also agree that Condor makesome lovely looking bikes and I particularly like their Fratello and Heritage models.
    However if you want to consider an off the peg option alongside the custom build options I can recomment the 2016 Kond Roadhouse.  I literally just got this bike and so I can’t give it a long term review just yet but so far I absolutely love it and it brings a big grin to my face whenever I ride it.  The RRP was £1,700 but as a 2016 model if you search around enough you can find some good deals now.
    If you want some more info on the bike see these links:-
    http://2016.konaworld.com/roadhouse.cfm
    http://road.cc/content/tech-news/176979-just-kona-roadhouse-£1699-reynolds-853-disc-equipped-bike-arrives-testing
    http://road.cc/content/review/182237-kona-roadhouse
    http://www.roadbikereview.com/cat/latest-bikes/road-bike/kona/roadhouse/prd_518029_5668crx.aspx
    https://www.youtube.com/watch?v=ltLN1bOXS10
    http://www.cyclechat.net/threads/kona-roadhouse-has-anybody-owned-or-ridden-one.206081/
    I like this bike a lot and it seems that other people who have ridden/owned it do as well.
    The one negative thing I can say is that as mentioned in the Road.cc review you do get a whilsting noise coming from the stem which is odd but if it bothers you this could be easily solved by getting a different stem.
    As menitioned if you shop around enough you can find some good deals on the 2016 model and so could be one worth considering for your shortlist.
    Good luck finding the right bike for you!
    John
    #877701
    Ogi
    I would go along the build
    I would go along the build your own bike route.
    Framesets:
    -Genesis Equilibrium 725 – 450 GBP (possibly discounted somewhere)
    -Genesis Volare 853 – 900 GBP (I’ve seen discounts for around 750), although quite aggressive geometry
    -Rourke 853 custome built – 1100 GBP
    -Rourke 631 audax around – 900 GBP
    This works on this specific build example (although you can play around, of course):
    Campagnolo Athena gruppo – 400 GBP
    Campagnolo Vento – 160 GBP
    Rest – 200 GBP
    Bikes:
    -Bianchi Vigorelli (sweet looking but not the best of value I guess, also not many LBS retail it).
    #877699
    Nick T
    Your budget might be in
    Your budget might be in Mercian territory frame wise
    #877697
    I’ve built to an Equilbrium
    I’ve built to an Equilbrium 853 and to a Nelson Audax (aluminium) frame set. £1700 is realistic, provided you enjoy the shopping element and don’t need to start riding immediately.
    If you’re serious about either of your two uses,  consider budgeting £300 for a dynohub front wheel and some German lights.
    Prepping your first unprepped frame is an experience – e.g. some headsets just slot in, others need a headset press.  Setting your crown race, your star nut and cutting your steerer to length are all fine with the right tools and a bit of experience or guidance.
    When I built a frame on a course, I got conflicting advice about facing the BB – no point doing it before painting it vs the paint goes on evenly – so I didn’t do it on the course with all the wear-withal present and ended up paying extra at the painter’s.  Other frames never got faced.
    Good luck!
    #877695
    Vejnemojnen
    #877693
    Dnnnnnn
    mike the bike wrote:
    I did a similar thing to Graybags.  Bought a Genesis Equilibrium frameset for £425 and built it up using mostly Campag Centaur stuff.  It’s really pretty, rides like a dream and, four years later, is still the bike I would save if the house caught fire.
    I reckon I did the job for about £1500.  I know I could have saved a couple of hundred by buying a complete bike but this way I’ve got exactly what I wanted, not just ‘near enough’.
    Get stuck in lad.
    I’m going home to check if my bike is still there ‘cos it sounds like you’ve pinched it! Is it a red one…?
    It is indeed in that gorgeous red.  People still stand and stare at tea stops, it’s that kind of bike.
    Even better when siblings meet.
    #877691
    mike the bike
    Get stuck in lad.
    #877689
    sanremo
    Thanks all for your comments.
    I think something akin to the Bob Jackson sounds intriguing.
    Mason Resolution looks a dream, but the additional £1000+ would mean saving for much longer!
    #877687
    VeloPeo
    Save more and get the Mason
    Save more and get the Mason Resolution. Big smile on my face every time I ride it.
    #877685
    Adrian_GJ
    Equilibrium disc is an
    Equilibrium disc is an awosome bike – you can get the frame and build it….
    I have two of those (one at my holiday place) and with some hand built wheels from “The Cycle Clinic) they are a great ride – and yes it comes under your budget.
    #877683
    Dnnnnnn
    Get stuck in lad.
    #877681
    mike the bike
    Get stuck in lad.
    #877679
    graybags
    I bought an off the peg frame
    I bought an off the peg frame from Bob Jackson, £500 I think including fork, they installed the headset (which I provided) and then I got my local LBS to build it up, mainly with Campag Veloce. It’s a winter bike, but frankly is my favourite !
