- This topic has 12 replies, 11 voices, and was last updated 10 years, 3 months ago by
TypeVertigo.
August 5, 2016 at 7:56 pm #26105
BobbyG
Hello all, I recently bought a new front mech, unbeknown to me that I’ll have to split the chain in order to install it (I’m sure years ago you didn’t have to do this!)
Anyway as a result I’ll be purchasing a chain tool, but what about the pin? Do I need a new one or can I simply pop the old one back in? If it’s a new one, do chain tools come with a few? (It’s the ubiquitous Shimano HG chain btw).
Cheers, Rob
TypeVertigo
While I love KMC’s
While I love KMC’s MissingLinks, for the life of me, I cannot separate them on my 10-speed chains without using some sort of tool.
Back when my folding bike still had a 1×7 drivetrain I found its MissingLinks were quite easy to disconnect by hand, in comparison.
roomservicetaco
If the chain is 9 speed or
If the chain is 9 speed or earlier, you can reuse the pin. When you press it out, don’t press it past the second outer plate. When you put the chain back together, press it in from the other side. After you press them together, you may have to wiggle the chain from side to side to get the chain to roll smoothly.
If it’s a 10 speed or later, you can’t reuse the pin. In fact, it will pop out of the outer plate when you press it out.
You can either use one of the master links as others have described or else purchase a replacement pin. Something like this: http://www.chainreactioncycles.com/us/en/shimano-chain-connector-pins/rp-prod52598
Just purchase the right one for 10- or 11-speed.
If you get a master link, it’s easy to install it – just put the halves of the master link together and stomp on the pedals while holding the brakes (i.e. put pressure on the chain without moving the bike). To remove the master link, you can do it with a set of channellock pliers, but much easier to purchase a tool such as this: http://www.ebay.com/itm/Removal-Replacement-Bike-Bicycle-Motorcycle-Master-Link-Pliers-Chain-Repair-Tool-/302036921255?hash=item4652cdaba7:g:OVoAAOSw9NdXqY2v
Relatively cheap from China.
nniff
I find that a squeeze with a
I find that a squeeze with a standard pair of pliers with a jaw offest on each side of the chain cracks them open easily enough and a quick stamp on the pedal resets them.
mike the bike
VeloUSA wrote:
VeloUSA wrote:Like Jack O, I am all in for KMC Missing Link. Simple to install/remove, inexpensive, and resuable. And by removing your chain makes cleaning your chain and drive train so much easier and faster.Me too. Can be a real time-saver when you have a mechanical out in the countryside; I have one on all my bikes and a spare in every saddle bag.
VeloUSA
srchar
I’ve opened and closed SRAM
I’ve opened and closed SRAM 11 speed “non-reusable” PowerLinks dozens of times without issue, as have many riding buddies.
IMHO there’s no need to get the joining pliers, just line up the link on the upper run of chain and bang on the pedals. You will, however, find life is considerably easier if you use the removal pliers, particularly for 11 speed links, and also a chain hook, which can be fashioned out of an old spoke.
Jack Osbourne snr
Bear in mind that the SRAM
Bear in mind that the SRAM powerlinks are designed to be fitted and not split after that.It’s therefore quite deliberately not meant to be easy to open them up!
The kmc version are easy enough to open or close without tools… Usually.
Duncann wrote:Does the chain have powerlink style connectors at the moment? If so, a pair of master link pliers (available for a few quid) are a good investment. I almost split my chain for fun these days…The first time I replaced a chain I’d watched YouTube videos saying to just pull this and that and then it would easily come apart.
How they lied. After finally managing to sort it all out, I went out and bought the appropriate Park Tool…
Jack Osbourne snr
I have kmc missing link chain
I have kmc missing link chain connectors on every chain I have… Kmc, Shimano and Campagnolo. They are reusable, meaning they can be split and reset many times although they should be binned along with the chain when it wears out.
They are also functionally superb… Much better than the SRAM powerlinks unless you never take the chain off for maintenance.
When fitting on a chain, you remove a full link ie two pins with joining plates.BobbyG
No PowerLink connectors at
No PowerLink connectors at the moment. Assume I would have to remove remove a full link from my chain & replace with the PowerLink?
Dnnnnnn
AKH
Some front mechs can be split
Some front mechs can be split so you don’t need to break the chain (the one on my old hybrid could do this), but all current road models I’ve seen require the chain to be broken.
You can’t reuse the pin. Even if you somehow manage to force it back in, it’ll either break or be too stiff and cause problems where the chain needs to bend. I doubt you’ll get a spare with the tool.
I wouldn’t bother with a pin though, I’d get this:
It’ll work fine with a Shimano chain, that’s what I’m running at the moment. Over 1,000 miles with no problem.
