Wet weather jacket?
  • This topic has 7 replies, 8 voices, and was last updated 11 years ago by amazon22.
  • #25060
    chilievans
    Hi all,
    My altura jacket, which I’ve had for years, is due to be replaced. The problem is that there’s so many options that I’m a little overwhelmed.
    The budget is around £100 and it’ll be used throughout the wonderful UK winter
    I’ve narrowed it down a bit:
    Altura vapour
    Endura flyte
    Endura stealth 2
    Any thoughts on these or any other jackets?
  • #863067
    amazon22
    I have an Endura Flyte and
    I have an Endura Flyte and can recommend it – it’s breathability is probably as good as it gets, using what sees to be a copy of eVent fabric. Where most jackets breathability are rated around 10-15000 (if the manufacturers even admit it), the Flyte is 28000gms/m2/24hrs. (The Vapour is 20000). Stretch fabric makes a comfortable fit, chest pocket is useful. It’s not a light racing jacket, not a heavy duty commuting jacket. It is also, for some reason, incredibly warm – it has no insulation but the internal fabric has a silver finish, which maybe reflects heat back, Whatever, it works.
    #863065
    rojre
    This is pretty good –
    This is pretty good – Impsport “Polar” Winter Cycling Jacket . £90.00 . Does wind and rain and breathes.
    #863063
    rosiel
    If you’re XS, S or M there’s
    If you’re XS, S or M there’s some Altura Transformers on Merlin for £37 (usually £90).. asides from that keep an eye on Amazon, some Gore Bike Wear stuff gets reduced to around £40 for £160 jackets around once a month..
    #863061
    peted76
    58 notes = galibier Tourmalet
    – SECONDED, new ish purchase for me, used about five times so far, haven’t got wet yet, the fit is racey and the arms aren’t flappy.
    Used in temps from 7 to 14 degrees with long sleeve merino base layer and long sleeve top – I expect this set up to last the winter temps with no extra layers required (on my top half anyway).
    If I could improve it, I’d have a couple of vents under the arms, but this is picking holes as for £58 it’s a peach!
    #863059
    dunnoh
    I have a gore element jacket
    I have a gore element jacket for commuting.  Its excellent.  If its chucking it down you will stay dry in it.  I have a gabba for when its potentially about to rain or drizzling but I dont use it if its already raining
    #863057
    part_robot
    I got super lucky with a
    I got super lucky with a (very slightly) shop-soiled Gore Oxygen 2.0 from Evans for £120. I don’t think there’s a better hardshell on the market. If you keep an eye out you might be lucky.
    #863055
    mostly
    58 notes = galibier Tourmalet, more than happy with mine. It looks very much like a goretex pac lite, performs better than a lot of my more expensive outdoor walking/climbing gear at twice the price, which is a rarity with most cycling clothing I’ve found.
