FELT AR 2015 fitting Rotor 3D+ (MAS) cranks issue
  • #24779
    Royal1664
    Hi Team,
    Anyone got a felt AR with Rotor cranks if so what spacer did you use. Currently the only way I can fit them is to have an 11mm spacer on the non drive side and no spacers on the right.The bike is bb30 with a 68mm bb.
  • #859355
    Royal1664
    James thanks for the post
    James thanks for the post mate!
    Found out that I had been sold one from a cervelo display bike so the cranks were factory make to only fit thoughs bikes!!! Bad times.
    Cheers
    Si
    #859353
    jimt
    I have but can’t see what you
    I have but can’t see what you are struggling with. (assuming you are using the 30mm axle ones)
    I have an original AR2 and have fitted the Rotor power cranks. No spacers were required. 11MM is quite a lot as far as I understand there should be no Rotor cranks that require a spacer that big on a BB30.
    On mine I have the bearing covers and did not require any of the very thin plastic washers. Do you have the rotary preload adjuster on the cranks?
    Thanks
    James
