- This topic has 3 replies, 4 voices, and was last updated 10 years, 11 months ago by .
Hope someone out there can answer this question, basically is there a minimum length the post has to reach UNDER the seat post clamp ie inside the frame or is it expressed as a ratio between the upper (exposed) length and the bottom (hidden) length.
I would assume that if you shorten the post under the clamp too much it might cause the frame to crack or split and obviously having a excessively long post in the frame is just wasteful.
