Creaking in left crank area
  • This topic has 5 replies, 6 voices, and was last updated 11 years ago by FatAndFurious.
  • #24514
    akelly524
    When I’m out of the saddle there is a creaking/ clicking coming from the left crank area. I’m thinking it’s the pedal crank as I had the bottom bracket replaced very recently. Has anyone experienced the same thing? I’ve got shimano pd-r540 pedals, if that helps.
  • #855355
    FatAndFurious
    #855353
    kaizoku0506
    Had this happen to mine a few
    Had this happen to mine a few weeks ago. Short-term fix was to tighten the bolts on the chainrings. This implied there was a little flex there. The long-term fix was to add an additional paper-thin shim when I was putting my cranks back on after servicing the bottom bracket.
    #855351
    What sort of
    What sort of crank/bottom-bracket are you using?
    Those pedals can be clicky when the bearings go bad.
    #855349
    Toro Toro
    Add: left crank correctly &
    Add: left crank correctly & tightly fitted! Bolts worked loose on mine a few months ago, and it wrenched off taking a local KoM.
    #855347
    2 Wheeled Idiot
    Could be so man things, check
    Could be so man things, check these and eliminate one by one..
    Cleats
    Pedals tight in threads
    Bottom bracket correctly fitted
    Front and rear skewer
    Bottle cage bolts
    Handlebar stem interface
    Pedal bearings
    The list goes on tbh, it’s just a case of finding the right thing and being methodical.
