Salt replacement
  • #24247
    ianrobo
    Because I sweat a lot I do have problems with salt deficit. I have tried all the hydration tabs like Nunn and powders but none seem to work. Any suggestions on something better ?
  • #850529
    bikeclips
    I’m for the belts-and-braces
    I’m for the belts-and-braces approach of having a couple of electrolyte tabs in each bottle in warm weather. You’ll pee out the excess sodium pretty quickly and if you drink too much then you’ll be protected against ‘water-intoxication’.
    #850527
    ianrobo
    Thanks a lot Crikey. The
    Thanks a lot Crikey. The second piece was very interesting as probably when really hot I do drink too much.
    I will need to plan out what to do because climbing in the alps when 25C at the bottom will be a test for me !
    #850525
    crikey
    Seeing salt on your top
    Seeing salt on your top doesn’t mean much.
    Do some reading around the idea that cramp isn’t caused by salt loss;
    http://sportsscientists.com/2013/01/dangerous-exercise-the-hype-of-dehydration-heat-stroke/
    You are more likely to be drinking too much than too little.
    http://sportsscientists.com/2007/11/sports-drinks-sweat-and-electrolytes/
    #850523
    ianrobo
    I do drink enough on rides
    I do drink enough on rides and not affected me this year because not been hot enough. It is just where I will be in a couple of weeks will be very warm.
    Reading up in preparation for it and seems that the issues I have is not dehydration but salt loss (should see my tops when real hot) including nausea, sickness etc which is not associated with dehydration.
    #850521
    crikey
    Sweating doesn’t work like
    Sweating doesn’t work like that.
    You sweat far more water than salt; therefore sweating increases the concentration of salt in your body.
    How do you know you have a salt deficit?
    #850519
    mill1991
    2 tabs per bottle? I was
    2 tabs per bottle? I was getting cramps on 3-4hr rides & have upped the concentration a bit & been ok so far.
