Carbon seatpost – lifespan?
  • #23879
    road
    Hi all, just a question regarding Carbon seatposts, Ive got a Bontrager that came with my bike, so its about 9 years old now, had light / moderate use mostly on B roads, Im 73kg and dont usually have anything else attached to the post (other than the saddle)
    I know there are discussions regarding Carbon forks and that they can fail suddenly, just got me wondering about the seatpost.
  • #843923
    Wow £180 for a seatpost
    #843921
    wellcoordinated
    I can’t recommend this post
    I can’t recommend this post too much. http://www.ergon-bike.com/us/en/product/cf3procarbon. Not sure about its durability, but it’s excellent over potholes!!
    #843919
    timb27
    The first one (that came with
    The first one (that came with my first bike) was overtightened. You could see this because it failed under the seatpost clamp, with severe compression to the carbon at that point. I overtightened it to stop it slipping, whereas had I used carbon paste I wouldn’t have needed to have clamped so tight.
    I then replaced it with the USE one, but the problem with that was the stupid seat clamp design failed.
    #843917
    interesting, ive not done
    interesting, ive not done anything to my seatpost, neither cleaned, nor lubed, nor used a torque wrench. Can you elaborate on your findings please?
    #843915
    timb27
    I had 2 carbon seat posts, a
    I had 2 carbon seat posts, a Bontrager and a USE. The first one failed at the seat post clamp, the second one failed at the saddle end. That second one meant I had to ride the best part of 40 miles on a sportive without sitting down. I now ride alloy posts on both bikes.
    Had I bothered to learn how to look after them and bought some proper paste and a torque wrench, I’m sure the first one would have been fine. The USE was a crap design, irrespective of the material.
    Now I know a little more, I might be tempted to give carbon another go, but tbh the alloy ones are perfectly fine, cheap and bombproof.
    #843913
    Good stuff, glad to know.
    And
    And cant say I’m surprised about the Boardman, dunno why I just wouldn’t trust that brand
    #843911
    Batchy
    Had a Ritchey Pro
    Had a Ritchey Pro carbon/alloy clamp seat post for 10 years/80,000miles now and it is still going strong. It has also been cleaned up and re lacquered with no problems !
    #843909
    tao24
    I have just binned a
    I have just binned a carbon/alloy seatpost (boardman) because the alloy head came loose from the carbon post. I have replaced with a carbon monocoque, which I hope will be useable almost eternally. Clearly any damage would cause a replacement to be needed, but the impression I have is that well made carbon parts should last indefinitely unless damaged, that normal road riding is unlikely to damage carbon parts and that failures are likely to be either manufacturing, installation (overtightening) or collisions.
    #843907
    DamienB
    Not heard that one – had a
    Not heard that one – had a couple crack/de-laminate around the seat clamp bolt/s so chucked them away and gone back to carbon post with alloy head. Heavier, but no more worrying that I will end up sitting on the end of the post when the saddle disappears.
