- This topic has 23 replies, 16 voices, and was last updated 11 years, 8 months ago by
therevokid.
February 18, 2015 at 11:17 pm #23297
richk13
I’ve just bought a Cube Agree GTC Race, my first carbon frame road bike and I got a bargain considering the spec. Thing is, I’m really struggling to get to grips with the twitchiness of the front end, particularly if there’s a bit of a breeze blowing. My now Winter bike is a Specialized Allez Sport which is Aluminium with a carbon fork and although it’s not massively heavy it’s a bit of a tank compared to the Cube (which weighs about 7.9kg).
So, it reasonable to expect a ‘lightweight’ carbon bike to feel twitchy and I’ll just have to get used to it? I’m 6’4″ so I’ve got the biggest frame size in both (which probably doesn’t help).
Any thoughts or comments gratefully received.
therevokid
I’d invest in a fit using the
I’d invest in a fit using the cube as the “base” bike.
solved several of my issues 🙂tom_w
If by twitchy you mean the
If by twitchy you mean the wind catches the front wheel and steers it (as opposed to ‘twitchy’ in the fast reacting to handlebar inputs sense), then I’d say it’s the bladed spokes and possibly the shape of the forks.I had a Merckx EMX 1 with Shimano RS10 wheels (which have bladed spokes) and forks that have quite a large trailing edge at the top of the fork legs (for aerodynamics I guess) and I think it was the combination of those two things that made it a real handful in the wind. I would literally get blown from one side of the road to the other; I hated riding it in the wind. It felt like somebody jerking the handlebars. I tried a different front wheel and that definitely helped, but it was still a bit of a handful.
I now have a different bike, with Kinesis cross wheels with round profile spokes and less aero forks and it is absolutely fine in crosswinds, you get a gentle tug now and again, but none of the violent change of direction.
arrieredupeleton
I agree about the position of
I agree about the position of the saddle looks quite forward. If you’ve shortened the stem already (which will make any twitchiness slightly worse) then my take is that you could have done with the 60 or 62 frame. It’s not unusual for tall pros (Johan Van Summeren who is 6’5”) to ride a 58 or 60 frame with long seatpost and stem. JvS is a classics rider and Paris Roubaix winner so I doubt he’d have the most twitchy of set ups.Anonymous
Looking at the picture of the
Looking at the picture of the bike, am I right in thinking that it has a zero lay-back seat-post? It’s quite hard to tell from the pic, but it does look like it.With the height you have the saddle, you are clearly long legged, and I would have thought you would want a fairly good amount of lay-back on the seat-post. You could counteract the increased stretch with a compact curve handlebar which would bring the hoods closer without reducing the stem any further and adding to the twitchiness.
You might want to consider going to someone like Enigma for a custom frame somewhere down the line. I had a couple built for very tall riders by them, and they were happy with the results, especially if you are long legged for your height.
@Rickh13
It is a really common problem, it seems sensible that making the cockpit shorter will make it all more upright and so more comfortable, but you have to have your position in relation to the pedals right first before looking at the other bits. You can always shorten the cockpit with compact bars and shorter stems etc.PonteD
DaSy, that’s exactly how my
DaSy, that’s exactly how my bike was when I first got it – twitchy, numb hands after about 20-30mins on the hoods and couldn’t ride on the drops as it was far too twitchy, felt like I was falling forwards all the time.I moved the saddle back and also flipped the stem to bring the bars higher up this moved my c.o.g. back so more weight is on the saddle with only minimal weight on the bars. I also found the position of the brake levers on the bars were a bit low for me and meant I was getting uneven pressure on my palms, they now support my hands with even pressure across the palm when I put my weight on the hoods.
It feels like a different bike now, its far more stable, but is easily thrown about when I need it. I can sit on the drops for as long as I need (just need to lose the gut so I can maintain a tuck 😉 ). Riding at speed used to scare me, these days it’s still edgy, but doesn’t feel like a bucking bronco that is waiting for me to relax my guard before throwing me off.
richk13
Malaconotus, yes, I have got
Malaconotus, yes, I have got the 64, it was recommended by the shop and is generally a similar size to the Specialized. I’ve got a 36″ inside leg (if that’s not too personal) so I think I’ve got reasonable saddle to bar drop. The photo below was taken before I changed and lowered the stem and tilted the bars forward a bit.richk13
Thanks, wellcoordinated. I
Thanks, wellcoordinated. I guess that’s what I was trying to get at, ‘are racy bikes more twitchy?’ If, as you suggest, they are, then I’ll just have to get used to it. If I put the bike on eBay, the wife will very shortly put me on eBay as well.Malaconotus
Have you got the 64cm frame
Have you got the 64cm frame and not the 62cm, then? Geometry is here… http://www.cube.eu/uk/bikes/road-race/agree/cube-agree-gtc-race-carbonnwhitenred-2015/ With a 220mm head tube and a stack of 616mm the 64cm surely can’t give you a huge saddle to bar drop, even at 6′ 4″? I’m 6′ 5″ myself and the best fit for me would be on a 62cm.The twitchiness is probably not just a function of the head angle as it doesn’t actually change from the 56cm up, all at 73 degrees.
wellcoordinated
Read this it will give you an
Read this it will give you an idea of why your bike is twitchy:http://calfeedesign.com/tech-papers/geometry-of-bike-handling/
You should be able to compare you Cube and your Spesh.
Unfortunately ultra racy bikes that are suitable for racing, are often oversold to the general public, and these bikes tend to be twitchy.
You should be able to ride no hands. If I couldn’t, and it were my bike, it would be on eBay. In the words of Chris Boardman “who wants a twitchy bike”.
Good Luck
richk13
Thanks DaSy. I’ll definitely
Thanks DaSy. I’ll definitely be giving the saddle adjustment a try this weekend.Anonymous
A common mistake I see in my
A common mistake I see in my workshop is that people trying to take the strain off their back due to a feeling of being too stretched out, tend to push the saddle forward on the rails to shorten the cockpit. This actually tends to make the situation worse, as you effectively move your point of balance forward in relation to the pedals, so you find yourself with more weight on the bars and having to push yourself back to stay in position on the saddle. This also manifests itself as getting numb hands or shoulders too.The position of the saddle in relation to the bottom bracket will be the thing that allows you to take you hands off the bars without dropping forward, as, if the saddle is sufficiently behind the bb you can resist with your legs on the pedals. The further forward that saddle is the more your point of balance and so your inability to resist falling forwards increases.
This combined with a short stem may well account for the twitchy feel. I would look at the fore/aft position of the saddle first and accept that you may feel a little more stretched out, but this soon becomes familiar.
richk13
Thanks again for the
Thanks again for the advise.I’ll definitely try moving my saddle back, stem up and doing some sit ups (if I really have to!).
I’ll stick with the shorter stem for the time being, and see how I get on (mainly because I’ve already put it on the Specialized as an upgrade).
Ta.
Poptart242
richk13 wrote:Thanks, for all
richk13 wrote:Thanks, for all the comments and suggestions.I guess I was trying to understand if it’s common to have this sort of issue when you reduce bike weight.
– I might try one of the wheels from my Specialized.
– The Cube already has 25mm tyres so I’d be reluctant to go any wider than that although will try reducing the pressure a bit.
– I did put on a slightly shorter stem as I was a bit too strethed out with the original. Only reduced it by about 20mm. I can see the front wheel hub over the bars so it may be a bit short, but it’s far more comfortable.
– I haven’t compared bar width but I will do.
– Don’t think I’ve tried riding no-handed on the Cube, I think the twitchiness has probably put me off. I do have the saddle high and bars low in a quite racey position so do feel a bit unstable and tend to fall forward even when I ride no-handed on the Specialized. Any thoughts on positional changes Jimmy Ray Will?
Thanks again everyone.
On the position – one from my recent fit. Place the palms of your hands on the hoods (don’t grip) and sit in your usual position on a turbo (or get someone to hold you up). If you can’t remove your hands without falling forward while remaining in the same body position, your stack height is too low, and you’ll be putting too much weight through the front.
Solution there is core strength exercises. And until you build that up, more spacers under the stem. I went down in 5mm increments until I couldn’t hold myself up anymore (only 5mm away from slammed! Been doing lots of sit ups to try to get there before summer 🙂 )
Speaking of the stem, 20mm doesn’t seem like much but it’s certainly enough to quicken up the front end noticeably.
notfastenough
Try to tell yourself to
Try to tell yourself to relax, breathe, flex your fingers etc when descending/cornering etc, as the risk is that no matter what changes you make, the knock to your confidence makes you stiffen up, which will just exacerbate the twitchiness.Jimmy Ray Will
Difficult to advise without
Difficult to advise without seeing you, but generally putting the saddle back will push your weight further back… accordingly you will need to shorten/raise the front end to compensate for the increase in stretch caused by moving the saddle back. -
