- This topic has 9 replies, 7 voices, and was last updated 11 years, 10 months ago by .
Hi Folks,
I’ve been putting off some semi-serious maintenance on my bike for a couple of months now for a couple of reasons. Firstly last time I attempted something new on my MTB I lost a tiny little rubber seal which sits between the two halves of my disc brakes without realising – leading to lots of drama with DOT4 fluid everywhere and no brakes, and secondly my bike time is limited, why spend it taking your bike apart when you could be riding.
Anyway, I’ve done around 2000 miles in the last 13 months on my bike, and the chain checker is now showing 0.75 which means I should probably change the chain, note that shifting is still as smooth as it ever has been on this system (Tiagra).
I bought myself a new Ultegra chain and a park chain tool, watched a couple of videos and I reckon I’ll be ok with that change, albeit I’m a bit nervous about it (see previous hydraulic brakes experience).
What I’ve been reading recently on here suggests changing the cables as well – something I’ve never done on any of my bikes. Bearing in mind it shifts just fine, is this really worth doing?
My bike has “outer” cables running to the downtube, then just the inners running to the BB, where the front derailleur goes into a tiny teflon tube inside the frame and comes out by the derailleur itself. The rear derailleur then has another section of outer cable which runs along the chainstay to the derailleur itself.
– Should I leave well enough alone?
– Do I replace the lot, outers and inners? My experience on cutting outers suggests that it won’t be such a nice job as the pre-cut correct lengths of cable that are on there now.
– How hard is it to dismantle a tiagra brake/gear lever to replace the cable?
– As the derailleurs are dialed in correctly already – I’m guessing touch nothing but the cable attachment points? Am I going to have to spend hours sorting out my shifting adjustments afterwards – when the front derailleur came off my MTB 20 miles from home one time – I had a hell of a time fixing it back on and readjusting everything – leaving me a little wary.I’m a mechanically minded bloke so I wouldn’t go to my LBS for this sort of job, does anyone know of any good youtube guides to point me in the right direction?
Cheers for any help,
