- This topic has 12 replies, 8 voices, and was last updated 6 years, 3 months ago by .
Hi all,
I have a Mango Point R with a groupset made up of 105 5700 rear derailleur, shifters and 12-28t cassette but an FSA Vero 50/34 crankset. Full specs at the end.
I’m having constant issues with the left crank arm coming loose and I’d quite like to complete the 105 set anyway by replacing the FSA Vero cranks for the 105 equivalents.
Things have moved on from the 5700 that was available when I got the bike so what are my options?
Should I look for the 5800 generation or can I go straight to R7000? I read somewhere I might need to change the front derailleur and shifters for compatibility if I did that.
The bottom bracket is a square taper, which BB will I need for the 105 crankset? Does it change depending on 5800 vs R7000?
Thanks,
Weight: 9.76kg / 21.25lb
Frame: 6061 aerospace grade alloy
Fork: Carbon bladed with mudguard mounts
Groupset: Shimano 105 5700 (10 SPD) shifters, derailleurs and Shimano CS4600 chain; FSA Vero crankset
Bottom bracket: square taper
Gear ratios: 12-28t, 50/34
Brakes: Tektro R315 Alloy Dual Pivot
Wheels: Vision Team 30
Tyres: Continental Gatorskin 25mm
Bar: Chasewood Team S Compact 420mm
Stem: Chasewood Team S 80mm
Seatpost: Chasewood Team S Forged Alloy 27.2mm
Saddle: Mango Bikes Upgrade Black cro-mo rails
