- This topic has 11 replies, 6 voices, and was last updated 15 years, 11 months ago by
Cloggie.
October 20, 2009 at 11:42 am #12004
the-daily-ripper
Question for you all – with the proliferation of aluminium freehub bodies to save weight, I’ve noted that my cassettes are eating them. Being a shimano user, is there a cassette that is virtually all on a carrier, as at the moment the non-carrier gears area happily gouging through my freehub bodies, essentially writing them off over time, and making changing the cassettes a pain in the bum.
Any suggestions? Needs to be shimano compatible…
Cheers,
ant -
Cloggie
Have installed a permanent
Have installed a permanent and easy fix for the damage issue related to aluminium freehub to steel/nickel cassette marriage. Okay, so it was easy but I am still brilliant (he said modestly).Tools/resources:
3 small bolts – circa 2mm wide and 15mm long after cutting off the head (as you get in a plastic multipack at your local hardware store).
Hardware nail cutter (if necessary, score the bolt with the cutter in pliers and break by bending with the pliers)
Metal file – to smooth the bolts where broken and smooth off some of the threading so that they insert easier.
Usual tools for removing a cassette.Situation
I run Shimano 105 10-speed cassette. Have had no problem with the original Bontrager (‘training’) wheels which have a steel freehub but now have some handmade racing wheels with aluminium (‘aluminum’ for my US cousins) freehubs.After around 600kms climbing French mountains (Tourmalet et al) I found that the cassette had damaged the freehub. The damage was not in the first 3 (largest) cogs as they are a single unit so pressure on the freehub is spread when in these gears. For some reason the 4th gear, which is a single, also had not done any damage (which is a bonus as it does not have the hole required for the fix as follows.
Gears 5-8 (the ones with the plastic spacers) had all caused damage. Gears 9 and 10 had not caused any damage (it seems that these both have slightly wider connections to the freehub and also there is usually less torque/pressure when on these gears).
Rectification
The main problem gears of 5 to 8 and associated plastic spacers all come with 3 holes in them that line up. So I just used some small threaded bolts that fitted snugly to insert into these holes and effectively made these 4 gears into a single unit.I had to remove the heads and cut them just less than the full width of these gears and spacers when as a single component.
So now when placing pressure on one of these cogs it will be spread to the others through the support that these bolts provide so I have the freehub splines and the bolts all working as one unit. Sure, the outside cogs of this unit (5 and 8) can still potentially move very, very slightly independently (ie not perfectly as one unit) but the overall support will help and it will stop the cogs cutting all the way through the freehub splines. Plus, the greatest damage was cogs 6 and 7 and as these are in the middle of this new one-unit section of 4 cogs, they will be the most supported. I have not used it yet on the aluminium spline and certainly will be interested in what it looks like in 6 months but I am completely confident that this is a permanent fix.
Oh, and I am sure that some people will wonder about the weight. It is 1 (one) gram. Nuf said.
The fix took about an hour (including after a few trys of other options). To do it again would be 30 mins easy.
carlhutch
We set up free trial days for
We set up free trial days for customers bikes at shops that stock our chainlube.I remove the cassettes and chain and give them a good degreasing before applying lube.Its so frustrating that each bike removing the cassette is such a hassle because of aluminium freewheels.You get a steel freewheel and the cassette slides straight off.
Any update on the bodge???the-daily-ripper
christ, just seen the price
christ, just seen the price of Red Cassettes – new freehub bodies are far cheaper!
dave atkinson
deffo worth a go, if it saves
deffo worth a go, if it saves your freehub body. break out the dremel multi and the araldite 😀 😀 😀the-daily-ripper
thanks Chaps – looks like I’m
thanks Chaps – looks like I’m going to be spending a fair bit of cash on cassettes, even for my bl00dy commuter bike at this rate!Alternatively, I might try and put a thin piece of steel alongside one of the edges so that the force is spread and going through a tougher material. The pocket clips on some of my pens in the office look like they might work – it’s worth a bodge attempt i reckon…
purplecup
Quote:not sure whether the
not sure whether the fact that it only engages through the end plate is a plus or a minus, since that would tend to concentrate the forces in one place rather than spreading them across the cassette
I’d suggest it’s mainly a plus because:
1) the SRAM splines are the same height as shimano 9spd, so the cassettes are a snug fit on 8/9/10spd compatible freehubs
2) the engaging plate is much wider than an individual sprocket is, so less likely to damage the freehub body
purplecup
i thought the sram red
i thought the sram red cassette was machined off of a big ol’ block of steel. is the back bit aluminium them?you’re right though cat1, it is a thing of rare beauty…
dave atkinson
i was suggesting red cause
i was suggesting red cause the cassette is a single CNCed piece… not sure whether the fact that it only engages through the end plate is a plus or a minus, since that would tend to concentrate the forces in one place rather than spreading them across the cassette.cat1commuter
… and cassettes from other
… and cassettes from other SRAM groupsets which are also available. Or are you only suggesting Red since the contact with the freehub is through the aluminium end plate, which is therefore the same hardness?(Always fancied getting a Red cassette, just as an ornament to keep on my bookshelf. It’s a work of art.)
I was thinking that with any non-Shimano cassette the problem won’t be so severe since their shallower notches will be a tighter fit.
Not having the spacer that the Shimano 10 speed cassette requires might help make things a bit more solid too.
dave atkinson
…and SRAM Red of course
dave atkinson
we were talking to a couple
we were talking to a couple of people – American Classic had most to say – at the shows about this. Assuming you’re running shimano 10spd the problem is that the sprockets have a reduced number of contact points which increases the load on the splines, and shimano have patented the deeper spline profile so other people can’t use it. So aluminium freehubs can get a bit gougedAC’s extremely clever solution is to insert a hardened steel strip to take the load. they’ve patented that though, so no-one else can do that either 😕
most wheel manufacturers who we’ve asked about the problem have basically the same solution: make sure you do the lockring up really, really, REALLY tight. the more contact you can get between the sprokets the better. Someone else told us that adding some threadlock between the sprockets before you do them up (really tight) can help as it increases friction between the sprockets and spreads the load. not sure about that though.
Prolite used to do a single piece CNC cassette (the Montechiaro) and Token do one too, i think. They don’t tend to last as long, or shift as well, as the more mainstream kit though. There’s a stronglight one with seven speeds on the carrier (i think) too
