- Tubeless valves
10 comments
In an ideal world then. With you FSA chainset, I'd have a SRAM Cassette, KMC chain and Ultegra shifters, brakes and derailleurs
Thanks for the clarity guys. It was something I was told several years ago and never knew if it was true or not.
If I ever get enough strength in the legs to be able to tackle the peak district on a double rather than a compact I now know best to strick with my current brand of drivechain rather than swap to a different brand...just to be safe.
Tim, the cassettes/chains and hubs are compatible, but as Tom notes, the length of cable pull for each shift is different between Shimano and SRAM, so you wouldn't want to mix shifters and mechs.
Not sure about chainsets.
Tim that is false. SRAM and Shimano operate on slightly.different draw lengths. They'll work together, but not well. Best go full drivetrain on one or the other imo.
Decide which shift style you like best, I despise Shimano shifting and love SRAM.
As I suspected there is lots of subtle differences that only experience or expensive experimentation can provide. Having only ever ridden Shimano I have no idea how the 'shift style' is. (If) when I buy a new bike I will consider Sram if it happens to come on a bike I am looking at. Meanwhile excellent point about the draw length on the cable so No. 1 rule, don't mix your shifters and rear mech.
Think I will save Dura Ace as a favourite on ebay and wait for someone to strip their wife's bike down, 'Thank you zealous bike husbands!'
I've always been told sram and shimano are fully compatible assuming you are comparing like with like (i.e. Both 10 speed)
I'm not sure if anyone can confirm this?
Also, not sure if you are a weight weenie, but if you are you might find the below link interesting to see how many grams you can shave off by up grading.
http://www.totalcycling.com/component-weights.html
Just from what you are saying.
I will make some suggestion's
SRAM Cassette, give me the number of gears you have and the spread you would like, i'll find you one. Because for instance, I KNOW there is a 10 speed that goes 11/12 - 36 I saw it yesterday.
Chains, KMC every time, they make SRAM and Shimano chains for them.
Chainset, Depending on if its compact, double or triple and the number of teeth, I can make a suggestion on that.
Then its a case of getting derailleurs to match, they should be the last thing on your list to find.
Unless you buy a full groupset (Which is easier, but more expensive)
My rear deraileuerer (start a whole new thread on your preferred spelling?) is a Ultegra, my cranks are FSA Gossimer, and my chain and cassette were 'shimano compatible' from ebay, I don't remember the brand or if they had one, but they work. Well this gives me at least an idea of were to start. I can see then why people sniff at Sora if it is near the bottom of the range on an expensive frame. Seems like I can only go up to Dura Ace unless I want to swap make or go hydroelectric (maybe for a new bike!)
I am not too bothered by the new 11 speed kit, I would be more interested if the extra gear was at the top end, not just filler. Believe it or not on the long gentle downhills of the Cheshire plain it is possible to max out on the 11 tooth.
I have just had a look at the PBK website for cassettes, the mid range goes up to about £55, anything top end quickly goes up to about £160-£230 (for a cassette!) So it looks like money and performance goes exponential, so I may have to lodge very much where I am.
As usual Gkam you are fountain of knowledge, this must come from being so close to the ground.
One of the factors is the number of sprockets - top of the range will have 11 down to 8 for the lower end of the Shimano range. And while the high number of gears is tempting they are more costly to maintain as the chains/cassettes wear out quicker.
I'd generally advise that 105/Centaur/Rival are about the same and provide the best value as anything above gives you diminisihing returns in terms of performance vs £'s.
OK, I will list from top components to bottom for the three main brands.
I won't even factor in that Ultegra brakes are the best Shimano brakes, but they are not the highest model....
Shimano:
Dura Ace (Di2)
Dura Ace
Ultegra (Di2)
Ultegra
105
Tiagra
Sora
2300
SRAM:
SRAM RED
SRAM Force
SRAM Rival
SRAM Apex
Campagnolo:
Super Record (EPS)
Super Record
Record (EPS)
Record
Chorus
Athena (EPS)
Athena
Centaur
Veloce
