Garage bike storage
I'm looking for inspiration on how to store a few bikes in my garage in a nice, space-efficient way.
At the moment I've got four (ish) bikes on wheelstands that take up all the floorspace in it, but for n+1 reasons, it would go down really well to get things a bit tidier.
Homebrew service course setup? Expensive metal hooks drilled into the walls? Meathooks hanging from the rafters?
What kind of budget are you on? I'm thinking a small one by the solution's you've listed?
So something like this, around £40, its a "lean to" stand for two bikes
http://www.tredz.co.uk/prodimg/35530_1_SuperSize.jpg
Then again, if you are quite happy to screw into the wall. Something like this for around a tenner
http://www.parker-international.co.uk/ProductImages/fullsize/qr40020.jpeg
Even cheaper, Just go to your local DIY place and get hooks like both of these use and fashion your own stand or hanger
Another option, get a car bike rack second hand, cheap and work out a way to cut and put it onto the wall.
http://ecx.images-amazon.com/images/I/61oR0U5XbDL.Image._.jpg
http://ecx.images-amazon.com/images/I/51UGVgGu7gL._SL500_AA300_.jpg
I think this is want I really want
http://www.cyclingnews.com/news/photos/inside-the-team-sky-service-cours...
I've had a look at some of the setups for sale online, and I reckon a few bits of 2x4 and some coated hooks might be the best option.
If you have roof space look up. I had a couple of pulleys and a nylon rope with carabiners for quick release. Quite easy to rig a hoist to keep them up out of the way.
I think I've seen something commercially available but it's quite easy to put together the parts from B & Q.
edit - here ya go http://www.amazon.co.uk/Silverline-554289-Bicycle-Lift-20Kg/dp/B003H72GV4/ref=pd_sim_sbs_sg_1
That sky set up will be custom made to fit their bikes and lorry. BUT, its simple enough to do yourself.
Depending on what you want to hook, the frame or the wheels?
Wheels are simple. Get this and screw it to a secure point on your rook
http://www.probikekit.com/uk/bbb-parkinghook-bicycle-storage-hook.html
Frame's are a little different, but I dare say that hook above would work. You would just need two for each bike, one for each side of the rear triangle.
Cheaper option would be to get these from your local DIY store like I said above
http://www.chainreactioncycles.com/Models.aspx?ModelID=32171
Excuse my poor job. I wasn't going to fire up autocad for this, So it was a simple MSpaint job.
The red being your garage, The black being wood or metal to secure into your garage and the blue being the hooks from wherever you choose to get them, laying it out in pairs like that for your rear triangle and they hook on where the drop outs are
I built four of these for my bike room. Super sturdy, good value (about £150 for the wood for 8 bikes do much cheaper than commercially bought stands) and they can be freely moved around without marking walls or ceilings. http://m.instructables.com/id/Vertical-Bike-Rack-from-2x4s/
I bought a wall hook from Halfords where you fasten it onto the wall.
Bikehut Bike Wall Storage Hanger costs 10.99. Simple to use and the hook is covered in rubber so the bike doesnt get marked.
Stumpy
I knocked this up out of some lengths of 2by2 the pegs are threaded bar cut to length then wrapped in foam (from bike packaging donated by LBS) as I don't have a garage
That's great! Did you put it together from a plan, or are you one of those people that can just knock things up off the top of your head?
If it was from a plan, could you point me in the direction? Cheers.
Step-hent, top one.
I was thinking of hooks on the wall of the shed and cross-bracing the other walls.
But these look a better solution.
Much carpentry ability required?
And how long did it take to knock one up?
Sorry Ade I just knocked it up but if you really want I can give you the measurements etc...
B&Q do these:
http://www.handymanhowto.com/2008/09/14/wall-mount-bicycle-rack/
Think they were £15 each or something. I have it drilled straight into the wall, you could just buy several and arrange as necessary.
Don't wish to cast a cloud over this but I'm currently rethinking my bike security after two serious bike thefts in Shropshire in the last couple of weeks. One chap had his TT bike, 2 road bikes and a MTB nicked. The most recent haul was worth £17,000!
Blimey. That's some job. They must have turned up with a van and just loaded it all in! Cheeky bastards.
we've got 5 road bikes at home hanging of a very simple setup:
a 1.8m long by 1.9m high industrial clothes rail : £30 quid:
http://www.shopfittingwarehouse.co.uk/shop-equipment-c8/clothes-rails-c1...
and some home made hooks with B&Q double hooks with some straps to hang them off the rail, and bits of old inner tube to protect the rims.
http://www.diy.com/nav/fix/hardware/ironmongery/hooks/-specificproductty...
Add a plastic sheet to collect all the crap from the commute bikes, and you've got a solution for 5/6bikes in a small area indoors for roughly £60-£70.
I won't add a picture fo the whole thing for security reasons as highlighted by Simon E, but here's one of the hook we've got.
Decathlon have some simple hooks that you screw to the wall. I have 5 bikes hanging of these:
http://www.decathlon.co.uk/cv-501-bike-hook-id_3760125.html
£3.99 each
From time to time Lidl sells a garage/shed-roof-mounting pulley system for about twelve quid. Strong and easy to use. Worth keeping an eye open for.
I've got to add that being in a rented flat, I could not put heavy duty screws fixings through the walls, and the rail can be moved easily or even put on castors to help that.
There are plenty of very cheap specialised hooks to hang bikes from garages walls.
Step-hent, top one.
step-hent wrote:http://m.instructables.com/id/Vertical-Bike-Rack-from-2x4s/
Very limited carpentry skills required - I didn't have any before I started, and not much more now! So long as you can measure, saw and screw self-tapping screws, they are pretty easy! I built all four in a day's work (a long day, admittedly, but as I said, my carpentry skills are limited!).
Good luck working something out.
I've screwed some old hanging basket brackets to my breeze block garage and used foam pipe insulation to protect the frame. Each bracket supports the top tube. Also used some redundant adjustable wall brackets designed for holding a microwave oven:
http://www.argos.co.uk/static/Product/partNumber/8405391.htm
I currently have four bikes in my standard sized garage AND I can park my medium sized car in there, only one bike is kept on the floor, the others are hung up on a side wall, also I have shelving and tools stored too!
Tags |
road.cc on YouTube
22 comments
