Seat post slippage
  • #13308
    nellybuck@msn.com
    The seat post on my commuter refuses to stay put; it continually slides down into the seat tube after a couple of km of riding.
    it’s the original seat post that came with the bike, and has only started relatively recently, but is getting really annoying now as it prevents me taking the bike on any longer rides as I’d be stopping every few minutes to readjust it.
    Any ideas?
  • #642543
    nellybuck@msn.com
    Thanks guys, will give that
    Thanks guys, will give that paste a go. It is the original seat post and clamp; the only thing I can think of is that I may have damaged something when I crashed quite heavily last year.
    #642541
    cat1commuter
    +1 for assembly paste stuff
    +1 for assembly paste stuff with plastic particles. The increase in friction is amazing.
    For your seatpost, clean out the inside of the seat tube first. I used a bit of rag pushed inside a loop on the end of some thick wire.
    #642539
    PlatosCarriage
    Coke-can shim! I can attest
    Coke-can shim! I can attest to its continuing usefulness, having an old Peugeot frame which no modern seatpost will fit. After a couple of comedy chin-on-the-top-tube moments I found three coke-can wraps to be perfect for me.
    Be brave and good luck!
    #642537
    j1mmy76
    You’re using the right size
    You’re using the right size seat clamp?
    #642535
    dave atkinson
    I’m assuming it’s the right
    I’m assuming it’s the right size for the bike and you’re tightening up the seatpost bolt, a couple of other things you could try are:
    1) Pace’s excellent carbon composite shield grease, which contains particles to grip components together and stop them slipping;
    2) A shim cut from a coke can
    the pace grease you can get at http://www.chainreactioncycles.com/Models.aspx?ModelID=26768
