15 comments
Yup, definately band on - it's a Microshift R8 FD on the Triban 500. The 500SE does appear to be braze on with an adapter though from looking at the photos.
R8 on the 500SE also. There's two versions https://www.microshift.com/en/product/fd-r253-bf/
Must say when I bought my 500SE I'd read the reviews of Microshift not being as well made as Shimano but so far it's been fine. I've worn out the hoods on the shifters but Microshift will post you two sets from Taiwan for about £6. They got here in about a week.
I had to switch the rear derailleur out for a Sora rear but only because the cable adjuster rusted and jammed solid. My fault for not cleaning off road salt. I snapped it trying to get it to move. I may see if I can drill it out and re-tap the adjuster. It shows scuffs less than Sora, which is a bit plasticky/painted.
The raw metal bits on R8 seem to oxidise a bit too readily for the UK but clean up with a bit of GT85.
No compaints otherwise. I'd rather have Microshift R8 than Tourney or Claris. No question.
Took my bike and left - as above, I have other issues with Decathlon. It's not so much his knowledge that was the problem, but the fact that he is allowed to work on bikes at all.
Decathlon is a great place to pick up cheap kit but is not a place to go looking for advice or knowledge in my opinion.
Did you show the "mechanic" the error of his ways or just walk off and leave it?
I've come across a few Microshift FD's... the bands are truly awful.
Poorly cast, equally poorly finished and unless you're careful, very easy to install in such a way that pressure is unequal around the band.
However, even if properly aligned, these Microshift bands feel so poor that even a slight over-torquing may be enough to do it.
Yeah my money won't be spent on mircoshift again - as above, you get what you pay for!
I've over 10,000km on mine on a Triban 500SE run through the winter(s). It's been totally reliable.
The only adjustment it's needed is to compensate for cable stretch after the first few weeks. Still running the same cable from new.
Yours was clearly fitted by someone paying attention to how it sat as the bolt was torqued up and they stopped tightening when they sould have.
In fairness, I suppose they are (at their price point) more "unforgiving" of lazy installation rather than being downright crap.
You get what you pay for. Go to the LBS or fix it yourself and take your chances with your own handiwork.
I agree, normally I do all my own work but this was a warranty repair so I let the shop do it.
Thinking back, what probably happened is that the employee was from another department and was just being helpful - instead of getting the actual mechanic to do it. I just think it's dangerous to allow this as my "ready to ride" bike was far from ready to ride...
Shifting from middle to big rings it went ping then crunch - no idea! It's a band on microshift jobbie and the band just snapped, too much tension I guess?
I called decathlon though and they said there was nothing they could do as it was only a 6 month warranty (convenientely the bike was 8 months old at the time). I then left a negative review and the team replied saying it's actually a 2 year warranty so back to the shop I went - luckily I hadn't gotten round to fixing it myself yet!
The problem with the shifter was that it would shift up fine, but would jump straight from the big ring to the granny ring, skipping the middle when shifting down. I hadn't noticed this but then I never used the granny ring. It's possible that the faults are related but I don't know.
In any case, I've completely lost faith in the bike (well the microshift components) and would prefer to upgrade to shimano/sram. If the deraileur had snapped at speed it could have been messy! The bike is a Triban 500 btw.
Are you sure it's band on. On my 500SE it's a braze on FD with a separate clamp.
So, how did the FD snap off then? We need to know
That's exactly what happened - easy enough to fix but down right dangerous if not spotted. He shouldn't have needed to touch the top cap at all (except to check the headset compression, which he didn't do either).
I know I sound like an old fart (still the right side of 30, just!) but he clearly didn't know what he was doing so shouldn't have been allowed near the workshop.
Not an issue this time around as I spotted it, but decathlon sells to many "average joe's" who may not know how a stem should be fitted and expect the bike to be ready to ride...
Sounds like the stem bolts were loosened when they turned the handlebar 90 degrees and they forgot to tighten them after tightening the top cap. Definitely sounds dangerous to me.
