15 comments
My brake cable for the back runs through the frame )that klunks at full lock as it tries to pull out of the guide
Drop these people an email, my friend was after something peculiar and they sorted him out https://simplybearings.co.uk/shop/Cycling-/-Biking-Bike-Bearings-Cycle-B...
No that's cool, I was trying to add my experience of setting the headset up for CasperCCC as well.
Anyway, I found the culprit that was causing my issue - here's the top headset bearing: https://1drv.ms/u/s!AnxxeTmvKEGujKkvExKtzSpQDDjc6w
Bottom one is not in bad nick so will just clean it all up and replace the top one and should be good.
Yeah so I've always used the instructions from the Cannondale manual re headset setup:
https://www.cannondale.com/~/media/Files/PDF/Dorel/Cannondale/Common/Sup...
Page 15
Key thing is to make sure the bung is lined up to support the bottom of the stem where it clamps and the bung is torqued up to 5 Ft-Lbs.
CasperCCC make sure the bung is tight and not moving up when you tighen, be careful to how much you tighten as the fork will expand and possibly crack.
Thanks guys, really useful info.
Think I'll strip it down at the weekend and give it a clean / see what state the bearings are in.
The bottom is a MR168 and the top is quite specific as its 6.5mm and i've never found a generic, but thats a tange 4t5-5, theres one on Ebay https://www.ebay.co.uk/itm/CANNONDALE-SUPERSIX-HEADSET-BEARINGS/14280684... also i would take both out and check which one is gone, as the bottom is the one thats open to the elements and more prone than the top.
I had similar clunking noises on my S6 Evo. Before replacing the bearings, I thought I'd give just cleaning it a go. Took the headset apart, cleared off all the gunk that had accumulated, and re-assembled it all. Totally solved the problem, so it might be worth giving that a go before you buy new bearings.
(Although... I've now got a separate problem, which is that it seems to be taking way too much torque to properly tighten the headset. There's a fraction of play that's just not going away. Anyone else faced this problem?)
Hi Shav the last comment was for CasperCCC, sorry for going off topic.
[/quote]
I had a problem with a SuperSix Evo Hi-Mod where the headset would come loose nearly every ride. It turns out that it can be a problem with integrated headsets and it is resolved with microspacers like these https://www.edinburghbicycle.com/fsa-micro-spacer.html .
I needed two of them to stop my headset coming loose and it has stayed tight since.
I always use Simply Bearings.
I bought some after market bearings for my evo. Half the price of originals and still fine 3 yrs later
Thanks for the replys, can I ask, where did you get the after market bearings from?
Australia is the best reply I can give you, sorry. I was racing in Australia and my headset died and the bike shop in Perth had cannondale bearings for (I think )$80 and I got some of the same pattern for $45. I've googled and found
https://cyclinic.com.au/products/cannondale-headset-bearings-road-caad-1...
https://qwertycycles.co.uk/collections/headsets
If the bearings themselves are the correct spec ie diameter and bearing face angle etc, then I can see no reason at all not to buy generics and fit them yourself. I did that on my carbon Giant.
