9 comments
Bookmarked! It's that I-Lock headset adjustment section rather than a "normal" aheadset.
It seems I inadvertently followed their instructions to the letter last night anyway. I'll whip the wheel off tonight and make sure it's sound as well.
May be worth checking the centerlock rotor is tight if you didn't do this when popping the bike together
If you turn the front wheel to 90° to the bike, then rock it to test for play, you remove the front brake from the equation. I suspect that the movement may just be the small amount of movement of the front disc pads within the caliper.
Edit to add:
The play in the headset of a Canyon is taken out by the little Allen or Torx bolt on the side of the bottom spacer. Once you have put it all together and tightened the stem onto the steerer, you take out the play but adjusting that little bolt, which force open a wedge type affair with the spacer to remove play.
https://www.youtube.com/watch?v=U5E5WLd4Chs
That's a super useful video thanks - they key thing being that the "thing" at the bottom of the stack opens and that's where the torx bolt is
Yep, I reckon its this as well
Not familiar with canyon specifically, but thinking you may need small spacer on top of the stem as shown here in order to adequately preload. https://www.youtube.com/watch?v=cQe9TJJq1PE
Canyon headsets don't use compressions plugs, they are completely different.
Have you made sure that the little star shaped screw is tightened up to take up any play? You have to go very careful with this as I have stripped one before. Don't like how they make them so delecate.
Sounds though as if you need to check out the wheel rather than the headset.
Where is this "star shaped screw"? I've seen this mentioned elsewhere but saw nothing of that sort there.
- There's a 2mm alan key fixing (2nm) on a large shaped spacer-type thing at the bottom of the stack.
- There's two 4mm alan key bolts (9nm) for fixing the stem to the steerer tube
- There's a 2mm alan key bolt fixing the stem cap to a thread within the steerer tube
- There's a 4mm alan key bolt within the steerer tube (which the stem cap screws into), marked as 4nm, which I was able to tighten slightly.
No pictures cos I'm at work
The one in picture 4 here, which is an alan key rather than a star shaped one, I'm either misrementering what mine is like, or it has changed slightly.
https://www.canyon.com/nl/service/supportcenter/article.html?supportcent...
