Hi all, I’m looking to try to simplify my trainer setup in a bid to appease my wife, and to also make my setup and go a little quicker.  I’m looking to use my iPad with a wahoo ant+ adapter to connect to my kickr, and I’m about to purchase the ant+ adapter, but need the Apple 30pin to lightning adapter.  Do I need to have an official apple adapter, or will the eBay ones work ok?  If so, does anyone have any links to the cheaper version of the adapters?
I’ve tried searching and could not find any answers.
12 comments
CXR94Di2 [1954 posts] 3 months ago
Apple!
bendertherobot [1494 posts] 3 months ago
What platform as you planning on using? If it's Zwift I'd look at whether the iPad you have is compatible.
David Arthur @d... [833 posts] 3 months ago
Why don't you use Bluetooth?
Forbez [6 posts] 3 months ago
It is using Zwift,  off the top of my head, it’s an iPad2.
i don’t think you can use Zwift to connect to the IPad and display via BT, or am I wrong?
apologies, I should have stated Zwift.
fukawitribe [2132 posts] 3 months ago
Doesn't look like Zwift (app) will run on the iPad2, Zwift support has iPad Air or higher, iPad Pro, iPad Mini 2 or higher, or iPod 6 as compatible - full details are on the App Store page here
https://itunes.apple.com/us/app/zwift/id1134655040
It’s an IPad Air2, just downloaded the App, and it works nicely from a rendering perspective. But I’ll give the Bluetooth piece a go, but I don’t believe that it will link to the Kickr via BT. But I may be wrong, and happy to be proved wrong.
Cheers for the responses so far.
barongreenback [114 posts] 3 months ago
I run Zwift on an iPad Air purely using Bluetooth - Tacx Flow plus Wahoo cadence and HR sensors.
I think you might be proved wrong I'm afraid  3
If the app works on your iPad then it'll connect to the Kickr via Bluetooth. I regularly use the Kickr on my Macbook via Bluetooth, and I've experimented with it on my iPad as well, which was just fine.
As previously mentioned the iPad Air 2 is supported, and will control the Kickr via BTLE.
Cheers guys, confirmed t works with the iPad Air 2 via BT.  Will have to check my Mac book too.
i appreciate the responses, and money saving that you’ve given me.
Thank you
ibr17xvii [270 posts] 3 months ago
Thank you
Macbook should work as well mate.
Thank you
No problem we're here to help  3
Can confirm it'll definitely work on your macbook, that's what I use.  I've tested both ANT+ dongles and Bluetooth, the latter seems to be more reliable with none of the occasional connection issues with the former
