17 comments
So long as it actually shifts properly, it sounds like the 'B screw' (derailleur angle adjustment screw) is too far out, allowing the jockey wheel to rub on the underside of teh chain where it moves onto the sprockets. Screwing it in several turns should solve it.
Did it ever sound fine? Just wondering of the chain is the right one... I've seen people put 9 speed chains on 11 speed gear and the noise is quite disturbing. Also, is the chain directional and installed the right way around? Have you tried a different chain?
Not chain rub on front.
b screw makes little difference
its worse following shimanos PDF
chain length is fine
yes only occurs when I pedal. Force on pedals makes no difference. It seems worse in the bigger cogs.
im thinking its bad tuning, chain is toast (even though it measures fine), my derailleur has too much play or the new hanger needs aligning to the frame
Does it only happen when you pedal then?
Have you followed the Shimano manual while tunning? Lots of people think they know how to setup a derailleur but don't.
Chain too long and rubbing on itself in lower gears?
B-screw adjusted correctly?
Are you sure it's not chain rub on the front derailleur?
So frustrating when you can't identify an issue I feel your pain!
It happens more or less straight away. The chain itself is pretty much silent other than you can faintly hear the rollers engaging the chain rings. I've only got a few hundred miles (3 waxings so far, at about 100 miles each) on it and I'm very impressed. No black gunge and a chain I can grab without getting my hands dirty.
It's the future (and the past) I tells yer!
I'm a lube man. I don't like the gunky build up you get with wax.
You shouldn't get a gunky build up with wax - the best thing about using wax is how clean it all stays. It sounds to me like you've tried wax and lube at the same time which is a mistake. If you use wax, you need to start with a brand new chain, degrease it completely and then wax it. Dirt won't stick to the wax, but will stick to any grease/lube.
The main detriment to using wax is that you need to re-treat your chain more often. I use a graphite/paraffin wax mix, so I remove the chain when it becomes noisier and heat it up to reflow the wax. (Well, actually I pre-treat a spare chain so that I can swap the noisy chain with the spare)
I use the out-of-the-bottle wax (squirt is the best one I've found). Obviously you need to thoroughly degrease a new chain before waxing; but after that I just clean it with a dry rag once a week to remove any build-up (roughly 100 miles) and re-wax it by putting a drop on the inside of each link - then giving it a quick spin and leave to dry overnight.
In my experience you could spend hours on this only to discover it comes from something completely random. I would check, probably in this order.
Or try looking in somewhere else, if you're only hearing these noises on the bike, they have a great way of throwing their voice. So check pedal axles, brake rub, front wheel bearings, seat clamp.
If that doesn't solve it, throw the bike away...
Do you use chainlube or are you a waxer? I converted to wax a few hundred miles ago and one thing I've noticed is that you can hear the chain riding onto the front ring as you ride.
Sounds like you need to re-wax or re-flow the wax if you've done a few hundred miles. I've found the chain needs a bit or treatment every 100 miles or so to keep it silent.
I can honestly say it's not that.. I've done it before too and won't do it again. It seems too be coming from the chain interface with the cogs..
is this my H screw do you think?
I've threaded a chain like that, but not ridden on it. As soon as I'd joined the chain and spun it round, I thought "that doesn't sound right". I'd bet 50p that's the problem.
Fourthed - no excuses. I've actually done it twice - but not for awhile
*Ahem* thirded. Got 200 yards into a ride and thought 'Hmmm, something definitely doesn't sound quite right'.
That sounds like a familiar noise. Check the chain hasn't been looped over the metal tab between the two jockey wheels instead of under it. I've done this a couple of times by mistake. It only adds a little resistance when pedalling - I did about annoying 50 miles before discovering it.
(Had put the chain back on with the bike upside down, in which position it's easy to do this.)
Seconded. I did that myself once (my defence is that I got distracted by having to break up a fight between my kids)
