How strong should a frame be?
  • #25900
    Grahamd
    A friend of mine just bought a Giant TCR advanced 2, and pomptly dropped it on his first ride while descending on a wet road at abount 20 mph. He landed heavily buckling the rear wheel, but worryingly has cracked the chainstay. The bike is getting checked out this weekend by LBS this weekend, but would have expected a bit more resiliance. Would appreciate you thoughts in case it is bad news from LBS.
  • #873609
    keef66
    “Thanks for your input, was
    “Thanks for your input, was brand new, he had literally had it 48 hours”
    Makes me feel a whole lot better about writing off a brand new tyre…
    #873607
    tritecommentbot
    Nice one, pretty much the
    Nice one, pretty much the best possible outcome there laugh
    #873605
    Grahamd
    Update, bad news that frame
    Update, bad news that frame was deemed irrepairable. Good news is that after some pressure from LBS to Giant, a new frame replacement has been agreed. LBS are charging £150 to move components between frames, so a good outcome I feel.
    #873603
    DrG82
    If the crack is in a nice
    If the crack is in a nice clear position near the middle of a tube it should be a fairly easy fix even to the point of a reasonably capable DIYer doing the repair. Just be really careful not to breath in an CF/resin dust when grinding back the area to be repaired as it’s really nasty stuff.
    Also, with it being a chainstay, if it goes again it’s unlikely to be a catastophic crash inducing failure.
    Fingers crossed it won’t come to this and Giant will sort it but, I’d guess the best you get is an discounted replacement offer.
    #873601
    Chuck
    I feel for your mate but in
    I feel for your mate but in my book this is just one of those things. Stuff can break when you drop it the wrong way and that can be the first time or the 1000th time you use it.
    Grahamd wrote:
    MHO the design should be strong enough to cater for real world bike use, and a minor accident should not render a frame unuseable
    I believe cars are frequently written off after ‘minor’ accidents so I don’t see why you’d expect that a bike frame would be indestructible.
    #873599
    fenix
    I’m sorry but crashing a bike
    I’m sorry but crashing a bike isn’t normal use.  Just like crashing a car isn’t.
    It’s unlucky for your mate – and 99 times out of 100 you’d be fine if you have a slight off – but bikes aren’t designed for impacting hard surfaces.
    I’m sure it will be able to be repaired though look up @Re_carb on Twitter. I’ve seen them do good jobs.
    #873597
    barbarus
    I think this sets the
    I think this sets the benchmark https://vimeo.com/24294789
    #873595
    racingcondor
    Sounds like bad luck
    Sounds like bad luck unfortunately, I’ve raced and marshalled a on and off for enough years that I’ve seen plenty of crashes and you’d be surprised how few broken frames I’ve seen.
    The good news is that I also had a friend who repaired their frame after cracking the top tube. Rode it for years afterwards with no problems.
    #873593
    fukawitribe
    Batchy wrote:
    Mungecrundle wrote:
    I lifted this straight from
    http://www.sheldonbrown.com/frame-materials.html
    It’s a few years old now and things move on, but he seems to put together some technically knowledgeable articles.
    “Carbon fiber is an increasingly popular frame material, but it is fundamentally different from metal tubing as a way to construct frames. Because of the fibrous nature of this material, it has a much more pronounced “grain” than metal does. A well-designed carbon fiber frame can have the fabric aligned in such a way as to provide maximum strength in the directions of maximum stress.
    Unfortunately, in bicycle applications, carbon fiber is not a fully mature technology, as tubular-construction metal frames are. Bicycles are subjected to a very wide range of different stresses from many different directions. Even with computer modeling, the loads can’t be entirely predicted. Carbon fiber has great potential, but contemporary carbon fiber frames have not demonstrated the level of reliability and durability that are desired for heavy-duty touring use. In particular, a weak point tends to be the areas where metal fitments, such as fork ends, bottom bracket shells, headsets, etc connect to the carbon frame. These areas can be weakened by corrosion over time, and lead to failure.”
    (Dated Aug 2010)
    CF is still a maturing technology. I’ve seen those trail bike frame tests before and they really do put paid to the notion that CF is not a strong material. However the fact that very few touring bike specialists use it for frames at the present time is a good indicator that it is not ‘better’ as an overall package than other traditional materials for all applications.
    Fingers crossed for a warranty frame replacement for your mate. Was it a brand new bike or new second hand? Giant may replace as a gesture of goodwill, especially if the alternative is an offer by your mate to post pictures of a cracked Giant frame all over the internet…
    The main reason for not using cf for touring bikes is because it cannot be adequately repaired unless you are fortunate enough to be in a place where facilities are available.
    However steel and other metals can usually be patched up or repaired by any competent village blacksmith even in remote areas of the world .
    Chances for repair in the wild would undoubtably be higher for steel frames in most places i’d warrant – i’d still hate to see your average village blacksmith put a flame anywhere near an aluminium or modern, performance steel/stainless one though. Also, much as I admire Sheldons site, i’d say that summary was nearly out of date at the time of writing – let alone now. I’d personally take a metal (probably non-exotic steel) frame for touring in out-of-the-way places, world circumnavigation and so on – otherwise i’d just go with whatever was to hand that took luggage and decent tyres.
    #873591
    Batchy
    (Dated Aug 2010)
    #873589
    Mungecrundle
    Is he sure that the frame
    Is he sure that the frame breaking was not a cause of the accident? A manufacturing fault may well manifest in early use. I’m sure that Giant would probably be keen to avoid graphic bad publicity and any product liability claim especially if your friend was injured. It’s a commercial decision for their customer support to deal with. Good luck
    #873587
    Grahamd
    Thanks for your input, was brand new, he had literally had it 48 hours.
    I’ve already encouraged him to contact Giant, as IMHO the design should be strong enough to cater for real world bike use, and a minor accident should not render a frame unuseable, hence asking the original question.
    #873585
    Mungecrundle
    (Dated Aug 2010)
    #873583
    Grahamd
    Thanks for the responses, let
    Thanks for the responses, let’s hope it is fixable, otherwise it will have been a very expensive ride.
    #873581
    fukawitribe
    Couple of other favourites…
    https://www.youtube.com/watch?v=SDVpRSNtcPQ
