6 comments
Have a look on Spa Cycles delightfully old school website. They are touring specialists, so sell a range of wheels built with dyno hubs. World's your lobster. Better still, phone them for a chat; they are both friendly and extremely knowledgeable.
Thanks guys! Some interesting bits of kit there. Given me a lot to go on
As for the hubs, I haven't seen a built wheel with a dynamo hub for sale, just the hub. Is it a case of buying the hub and taking it to a shop and asking them to build a wheel? I'd love to build it myself, but I don't really want my first wheel build to be with my shiny, brand new, very expensive hub!
I have a luxos-u and love it. If I am travelling fast enough at night it powers full beam front, back light and also provides USB power. Light will drop to low power in daylight or if moving slowly. When you stop, the back light remains on powered by the storage battery in the front light. No adaptors needed as you just connect your dynamo directly. I'm using an SP PV8 dynamo. Expensive but worth it.
You clearly have better fortune than me. My luxos lasted a month before dying of Scottish weather. Fair enough, B&M replaced or repaired it (never discovered which ), but i never really trusted it after that, so sold it and now have a Supernova. Not as good a light I think, but has survived some soakings.
There's plenty of options. Make sure you get a high-output hub, 3W or above, if you want to charge stuff. I've used an SP PV-8 on long rides to good effect.
To get USB power you need some kind of adaptor. some options:
B&M Luxos-U light: dynamo light with a USB charging port
http://www.bike-discount.de/en/buy/busch-mueller-lumotec-iq2-luxos-u-led...
Axa Luxx 70 Plus: same deal, a lot cheaper
http://www.rosebikes.co.uk/article/axa-luxx-70-plus-steady-auto-front-li...
Supernova Plug - fits into your steerer tube
http://www.rosebikes.com/article/supernova-the-plug-iii-usb-charger/aid:...
Busch & Muller E-Werk (as mentioned above)
Biologic Reecharge: battery pack that can be charged from dynamo
https://www.athleteshop.co.uk/biologic-reecharge-power-pack-laadstation-...
Twinheads Lightcharge: simple USB adaptor, not sure if you can still get it
http://road.cc/content/review/128411-twin-heads-srl-lightcharge
It's slightly less efficient overall but I'd recommend getting a decent capacity USB battery (10-15Ah) and charging it up before you go. they're cheap as chips and it'll be days before you need to faff around with USB leads on the go. when it's running low you can charge it up from the hub, all day.
The other thing to make sure is that you have a good quality USB lead. If everything you have is one connection, Micro-USB for example, fix it to the port in some semi-permanent way (Sugru is good for that) and tie the cable to somewhere you can easilycharge stuff, like a bar bag or front pannier. The other good thing about using a battery as a go-between is you only ever need to connect that to the hub, so it can be connected and charging the whole time. Any other leads you can keep safe in your luggage.
I've got an Shimano Alfine dynamo front hub that just runs B&M front/rear lights. AFAIK you can mix and match hub with components to some extents as it's just a standard output. When I was searching for somwhere to buy from I used SJS Cyles and they've got loads of bits in stock, one of which is a USB battery/supply and looking at the images it's got the dedicated Shimamo connector so I guess it would function. Trying giving them a call.
As to how well, dunno!
http://www.sjscycles.co.uk/busch-and-muller-usb-werk-prod35592/
