- This topic has 8 replies, 6 voices, and was last updated 10 years, 11 months ago by .
I have a nice 2004(ish) Giant OCR0 – not too new, not too light – road bike I’m perfectly happy with.
It came with 9 speed Campagnolo Mirage (Triple 30-42-52 + 12-23 casette) which was fabulous on flat Dutch roads. I’m also quite content with the Mirage… after all these years I have only replaced the derailler wheels. Reliable and durable.
The issue I have now I have moved to North Lancs… those pesky sections of 20%. I can just about brute force shorter sections, but it is not comfortable. Unfortunately Campagnolo don’t do a 9 speed 12-27ish casette.
I’m worried on the whole spin-out issue if I’d loose the 12, else going with a 13-28 would be great.
Alfine 11 city/tourer vs current OCR0 gearing:
Development using the Alfine 2.28m – 9.32m
Development current OCR0 2.78m – 9.25m
I actually use all of the gears on the Alfine (although the 11th rarely, mainly because it tends to stay in and around Lancaster), and that is using a pretty relaxed position on 15KG of bike.
Current OCR0 vs 13-28 casette
Development would range from 2.29m – 8.54m
This is perfect on the bottom end; but rather short on the top end (Only just longer than 10th on the Alfine, which I’m sure would spin out on long clear descents)
Ideally I’d find a 12-28 casette that works well with Campagnolo, as the alternative, upgrading to Athena 11 or similar would be a bit more costly (Although much less than a new bike with Athena 11 or similar from Sram/Shimano)
Any recommendations or ideas to consider?
