22 comments
The final word on changing to a 12-30 cassette. Yes it works fine with an Ultegra 6700 short cage rear derailleur. Only noticed a slight benefit from my 11-28 but I can spin a little more on those big hills.
Had my chain come off a couple of times since having the new cassette and new chain but after following this video
www.youtube.com/watch?v=tfBiXgf8JxI
and adjusted my front derailleur, it would seem that it was miles out. Now adjusted properly it has never shifted so well.
Thanks guys for your input, it made me go for it, even though Shimano say it shouldn't work.
Thanks for reporting back, it's good to know it works.
If it unships the chain again I would adjust the front mech high limit screw (the outer one) See the Shimano 1-page guide:
https://www.bike-components.de/bedienungsanleitungen/2011/shimano/rennra...
If you subsequently find shifting onto the big ring isn't as smooth and/or the chain rubs the mech in top gear then reverse the adjustment.
Thought I would report back here now that I have had chance to try my new set up.
Had my new Ultegra 12-30 cassette and Ultegra 6701 directional chain fitted at my local bike store. Got them to service my rear hub at the same time, which apparantly needed a new bearing.
My RD-6700 short cage derailleur looks at its extremities when on big to big and small to small rings, but I shouldn't be in that gear at any time.
Did a 28 mile ride the other day. All shifting seemed smooth and I would have reported it to be trouble free if it hadn't been for my chain coming off at the 20 mile mark. It came off the outside of the big chainring when shifting up. It went back on easily...but certainly something to watch.
Don't know whether it was because I hadn't been out for a month or because I had put some weight on over Christmas but was really sluggish(slow). I actually didn't notice the benefit of the 30 over a 28. Neither did I miss my 11 for a 12.
Will see how it goes. Thanks all for your comments.
will work fine on a short cage no issues. My bike came with this setup for some reason 28 would have been for me at anything below 10%
Yeah your probably right there. I have been using a 28 for the past two years, but on those really steep hills have felt that I need another gear. Rather than get out of the saddle for those I can hopefully stay seated an spin a little more with a 30. Will see how it goes.
Today I had the 12-30 Ultegra cassette and 6701 Ultegra directional chain fitted. Also had my rear hub stripped down, serviced and a new rear bearing. Gearing seems to work fine when hung on the wall of my garage. Just need a dry day to test it properly.
The 30's only there as a bail-out gear surely, so you would only really need it when already in the inner ring. (I say this with a 32 on the back of my CX )
As others have said, it'll work fine. I plonked a 12-30 on my 53-39 for Lands End to John O'Groats last summer, and with the tension screw all the way in I had no probs at all with my ultegra short cage rear mech. So much so that the cassette is still on the bike...
I have used a 12-30 cassette with a 50/34 chainset and short cage rear mech on my Orbea Avant without problems. It is a bit tight when on the big ring front and back, but how often do you ring that ratio? In my case never!
I get your point. If big ring to big ring is the only problem then I can live with that, because I rarely go into that gear and can easily avoid it if I know its a problem. I presume it can cope with changing up to a 30 which is obviously larger than a 28.
Yes no problem
Think I probably have a SS and don't want to go to the expense of a GS. Will have a chat to my local bike chap to see what he thinks. I can alway exchange the 12-30 for a other 11-28.
My bike is a Giant TCR Advanced which runs a 12-25 as standard, so will have to see if there is room for a 12-30 on an SS....but interesting to hear it has been done successfully.
Yes - Shimano always understates capacity a bit. Put the bike on a workstand and crank in the B-screw until it clears. Shift through all combos and make sure your chain is still long enough to go Large/Large without being screaming tight. Longer cages on RDs handle more chain better
For some reason, Shimano always understate capacity. Not only was it fine but I rode up Alpe d'Huez on it.
See extract from tech spec sheet
I have just found the tech spec sheet on the net for the RD-6800. On all counts is has the SS max size sprocket as 28T and total capacity as 33 teeth. That would rule out a 12-30.
Strangely it shows the GS also having the max size sprocket as 28T but with an overall capacity of 39 teeth.
It seems that the bigger sprockets may fit but Shimano do not recommend it.
It would certainly work with a GS
I've an 11-32 with this rear mech
Yes.
I've used 12-30 Ultegra cassette with Ultegra short cage RD on a Roubaix and it's fine. I just have to screw in the B-tension slightly so that the jockey wheels don't hit the 30t sprocket when it's on 34x30.
The proviso is that some bikes will have slightly shorter mech hangers.
Not sure if mine is an SS or a GS. I suspect it is an SS. Does anyone know the difference in measurement of the cage as I can't find any model markings on it.
https://www.google.co.uk/url?sa=t&source=web&rct=j&ei=JwmnVLbPIMz4UILDgL...
This shimano pdf list part numbers. Carefully check, but I would bet that you have a ss rear derailleur.
That link id for the 105 RD-5700, but I have managed to find the same thing fot an Ultegra RD-6700. Finding the parr number on the rear mech is a different matter though.
Change your rd to gs model and then you can fit upto 32T.
