16 comments
Further to the spoke advice, my rear Zipp clincher occasionally makes noise. Instead of at the end/nipple, a drop of oil where the spokes cross is the fix, and it lasts quite a while before needing to be reapplied.
Just
oil
the
spokes
It's not rocket science.
It seems to be totally alien to people who rely on everything a LBS tells them....
There is a REALLY basic and simple test either you or the bike shop could carry out to find out where exactly on the wheel the noise is coming from.
Those sticky coloured dots you get for marking things on a calendar, get a mixed pack of those, 5 colours I think, then every third spoke or so that are matching at the either side of the wheel, so if yellow is at the bottom, yellow is also at the top, place a different colour, go out for a little spin around the block with someone, every time you hear that noise, make sure they see which colour is at the bottom of the wheel.
This way you are narrowing down the area of the wheel that is making the sound. You then have two areas to focus on, being the top and bottom of the wheel on X colour. eliminating the rest of the wheel.
If it is the tyre like they think, it sound be a simple thing to find, if it is the spokes and most of us think, it should also be a simple case of tightening up one or two of them. As happens with ALL wheels, they are set at the right tension when built, off of a bike, as soon as you put a frame, components and a rider on there, the tension soon needs a slight tweak.
Personally, if you have been back to a LBS more than 3 times with the same problem, I'd be loath to use them again, unless you really have no other option and cannot do it yourself.
not yet, but I'll give that a try next...
Did they oil the spokes?
quick update, my lbs checked the valves, speed sensor on the front hub, quick releases, spokes, shoes, cleats, pedals, the tick/click noise is still present when I'm pedalling, I've used dura ace c24 clincher wheels previously with this bike and they were fine no problems, so it can't really be gears/cassette?
Another vote for the valve stem tapping the wheel on each revolution. Speaking from my experience with deep section carbon wheels.
It's not the valve I've got a little thing on that holding it in place, I'll mention the spokes next to my lbs. definitely no pinging/tinging type noise though?
If the LBS think it is the tyres, that says to me they are not confident with their own skills on gluing tyres, so I would avoid them for that job in future.
Pretty sure it will be the spokes though, never heard a tyre, even if it wasn't seated right making a ticking noise.
Does it 'click' every rotation? Valve stem tapping on the rim every rotation? Try applying some electrical tape to the valve stem to see if it stops
Ive no idea why they're farting about with the cement, it's not that. It goes away as they're probably getting the glue down the spoke holes and that lubes them... For a while.
Do as the lads suggest, it's very common.
It's the spokes, try it.
I don't think its the spokes because when my lbs reglue an area of the tyre it's fine a for a few miles, front tyre was making loads of noise then that got sorted, now it's the back tyre starts very faint rotational ticking, definitely no spoke type noises I'm hearing but you never know maybe that's next...:-(
It's the spokes.
Take the wheels off, put a drop of oil on each spoke end at the rim, then stand next to a radiator and give them a turn every so often.
It's the sound of spokes under high tension re-seating with each revolution; it's not a major issue, but it does get annoying. The most common cause is people washing their bikes too vigorously!
Sounds more like the spokes rather than a tyre, might just have one or two needing nipping up, else they will have a pinging/ticking noise.
