Windstopper Base Layers for Autumn/Winter Riding
  • #22598
    Goyt
    Hi all,
    I’m a new cyclist preparing for some colder weather riding and am wondering what people’s opinions on Windstopper or windproof base layers are?
    Are they a useful item to have for late autumn/early winter riding without a softshell jacket? Or is a traditional three layer setup better? I don’t have a proper cold weather cycling jacket yet so if I can put off that investment for a while longer I would be happy.
    I’m pretty much just a recreational cyclist, 100km Sunday rides. Felt a chill on my last ride (approx 10º) so am looking for something warmer but not too warm for the autumn weather.
    Thanks
  • #818369
    massspike
    I like my Santini Windproof
    I like my Santini Windproof Base Layer top. I’ll wear it under various windproof jackets (microfiber, softshell, Windstopper) depending on how cold it is going to be. This covers a -10C to +10C temperature range.
    The Santini design employs different materials so the additional wind blocking is centered on your core which takes away the additional wind chill I can feel without it. This is particularly so when you start to perspire.
    #818367
    mtbtomo
    +1 for the Aerofit BTwin.
    +1 for the Aerofit BTwin. With a vest, this and a normal cycling jersey it was spot on today, possibly a bit too warm.
    I find if you have windproof sleeves (say a with a softshell), then unless its really cold it it all gets a bit sweaty.
    A really versatile bit of kit, cos you can wear it even when its quite warm without it being too hot.
    I’ve also got a Gore Windstopper cycle jersey that is similarly good (but much more expensive) when used with arm warmers.
    #818365
    CXR94Di2
    I wear a full sleeve Nike
    I wear a full sleeve Nike wick layer, an old full cotton shirt, then my windproof altura jacket. Full length leg and winter cycling boots. I am cozy down to -2 deg C. My hands, I tended to use wind proof gloves but found I sweated too much, I now use woollen type and they breath a little whilst warm.
    #818363
    Dutch25
    I use it all winter. Went out
    I use it all winter. Went out last weekend and was about 5 degrees at 7.30am. Rode with a jersey and thin gilet on. Also a pair of arm warmers on until it warmed up a bit. Although a bit chilly setting off as soon as I was riding I was plenty warm enough. Have worn it on rides where temps don’t get above 2-3 with a regular jersey and thin windproof jacket over the top. Suppose it depends on how much you feel the cold.
    #818361
    BBB
    Have a look at Endura F260
    Have a look at Endura F260 Pro long sleeve jersey.
    Not strictly a base layer but it’s very thin with front windproof panels (chest and arms) and breathable rear.
    It works for me from 5 to 14 deg either on its own or with base layers.
    http://www.evanscycles.com/products/endura/fs260-pro-jetstream-iii-jersey-ec047590
    #818359
    Goyt
    Thanks Dutch25 for the
    Thanks Dutch25 for the feedback, that’s one of the base layers I’m interested in.
    Do you find you can use it with just a jersey in autumn weather, say around 10º and below or do you still need an outer layer on top?
    #818357
    Dutch25
    I have a B’twin Aerofit
    I have a B’twin Aerofit baselayer from decathlon. Has a windproof chest panel and is well ventilated on the rest of it so not clammy at all. Works brilliantly on cold winter mornings. Only £35 as well so significantly cheaper than a lot of other baselayers.
    #818355
    matthewn5
    Totally recommend the
    Totally recommend the Giordana FR-C. Windproof breathable front, waterproof shoulders and fronts of arms, warm fleecy back. Best cycling garment I’ve ever had. Just needs a light base layer under it, or even on its own if its warm. Shrugs off the odd heavy shower, never gets clammy. The poor man’s Gabba.
    #818353
    Shouldn’t the windproofing be
    Shouldn’t the windproofing be on the outside? I’d have thought it would get clammy next to the skin.
    Have a look at these http://road.cc/show/review-section/gilets/9764
