here's the blurb from my ebay listing - see pics on ebay also
https://www.ebay.co.uk/itm/Cannondale-Slate-1x11-custom-build-Shimano-XT...
CANNONDALE SLATE, CUSTOM BUILD WINTER 2017
Bike is listed as 'Used' but has only been ridden to set up the new components.
I stripped and re-built the bike from new around a 1x11 drivetrain in October 2017. The 'army issue' green framset is no longer available in the UK having been shipped in limited numbers.
The bike is in immaculate condition with most components being brand new with no wear (e.g pedals, groupset/chainset etc) other than being ridden for around 10k in order to set up the bike properly.
I colour coded using all Black components for a consistent look, including rear cassette, KMC chain, cranks, chainring, stem, bars, tape etc.
The bike was built as a fun and versatile road, cyclocross & gravel bike that can also be used for measured training via the Cannondale Hollowgram & Stages POWER Crank.
The drivetrain has been built around a 1x11 set-up for minimal fuss, using a Shimano XT rear derailleur (with clutch) & Cannondale SiSl Chainset.
The bike has a 40t Cannondale Spidering up front, with an 11-36 rear cassette which gives a gear inch range from 28.8 to 95. Ive installed a Tanpan by Wolftooth which means shifting is flawlessly smooth and silent paired with the Shimano XT M800 Shadowplus clutched rear derailleur and KMC Diamond-like-coated Chain.
The Mavic 650b tubeless (or tubed) rims are currently fitted with 45mm Panaracers, or can be shod with 30mm road-focussed rubber (such as Schwalbe G-One speed tires supplied) so the bike is hugely versatile.
ORIGINAL RETAINED COMPONENTS
FRAMESET - Cannondale SLATE 2017, Green with yellow decals
FORK - Cannondale LEFTY Oliver Carbon, 30mm travel
BRAKES - Shimano RS505 Hydraulic disc, Front and rear
STEM - Cannondale C1 Alloy, Black
DROP BARS - Cannondale C3 Alloy, Black
RIMS - Mavic XM 419 Disc, 650b, Tubeless (or with tubes if preferred)
TYRES - Stock Panaracer tubeless +
SEAT - Fabric scoop radius sport (as pictured)
UPGRADED / NEW COMPONENTS
REAR DERAILLEUR - Shimano XT M8000 Shadowplus with clutch, 1x11 drivetrain (rrp £75)
CRANKSET - Cannondale Hollowgram Si Cranks (rrp £90)
LEFT CRANK (INTEGRATED POWER METER) - Cannondale SiSl Hollowgram with integrated STAGES Power (rrp £599)
RIGHT CRANK - Hollowgram Sisl integrated power meter Left Crank - 170mm (rrp £90)
CHAINRING - Cannondale Spidering Si 40T (rrp £75)
CASSETTE - Sunrace CSRX1 11-speed Cassette, 11-36 black (rrp £45)
SEATPOST - FSA K-Force Carbon (rrp £130)
CHAIN - KMC X11 SL DLC Chain, Black (rrp £79)
WOOLFTOOTH Tanpan seamless shifter (rrp £45)
PEDALS - Shimano xt M8000 pedals (rrp £60)
BARTAPE - Cinelli Gel cork, black
additional extras included with sale (including replaced components for spare)
brand new Schwalbe G-One speed tires, 30mm (rrp £80 pair)
Cannondale stock seatpost
Cannondale SL Cranks
Spare Cannondale Spidering Si 40T (rrp £75)
FIZIK Arione, Carbon Braided saddle (rrp £200)
FSA 52 x 36 Front Chainrings
Shimano front mech
Hollowgram Crank Extraction tool (rrp £25)
Cannondale spider lockring tool (rrp £15)
